Arduino CNC Shield | Spindle speed | Estlcam
Hello,
im building a mpcnc and want to control the spindle speed. The spinle i use is a common 500w china spindle with an potentiometer/0-10v input for speed.
I already found out that the cnc shield only got 5v. No problem with an 5 to 10v board.
But there is a problem , Estlcam got PWM with 8khz, but the 5 to 10v only understand 1-3khz.
Does anyone got a solution for this ? On a german forum i found a solution with an second small board to translate 8khz to 1khz, but i think its not optional.
You can use a transistor to turn a 10V signal on or off at 8kHz with a 5V PWM 8kHz signal. Is that what you want? You might also need a resistor & capacitor on the output to act as a low pass filter to smooth the 10V PWM to a smoothish analog signal, but the speed control may already do that.
The transistor circuit (a high side switching circuit, with a PNP transistor and a pull down resistor) would be cheap, and diy, but you may have better luck with a level shifter that is premade, like this:
It’s delay is measured in nanoseconds, so I am sure it would handle 8kHz.
The problem is, the 5v to 10v board can only work with 1-3khz. But the Ramps delivers 8khz.
If the board gets 2V with 8khz it ouputs 10V, because the board cant handle 8khz.
I got a 5v PWM 8khz Signal and need a 10V analog signal.
What do i need ?
A level shifter from 5V (PWM) to 10V analog.
or
5v 8khz to 5v 3khz
the board which i could use : (i cant include links)
I’m suggesting replacing the 5V to 10V board with the level shifter that can do 8kHz. Changing frequency is much harder than voltage.
It is too bad the Estlcam firmware isn’t open source, it would be possible to change the frequency in Marlin.
I cant find a level shifter 5to10 with 8khz. Do you know one?
The one I linked from sparkfun.
