Apologies for the format below but I keep running into an issue with a simple drawing gcode that is triggering the machine soft limit (Soft limit on X target:-1625.076). I’ve manually reviewed the gcode in the section where it stops but all moves are well within limits. Any ideas on how to troubleshoot this? I’ve tried 3 times and it throws the error at the same spot every tiime.
[MSG:INFO: Soft limit on X target:-1625.076] <Run|MPos:246.180,198.840,-17.230|FS:557,0|Ov:100,100,100|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:246.180,198.840,-17.500|FS:1260,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:246.200,199.300,-17.500|FS:777,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:246.440,200.360,-17.500|FS:1261,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:247.020,200.460,-17.500|FS:1800,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:248.060,199.460,-17.500|FS:1800,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:249.200,198.020,-17.500|FS:1800,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:250.300,196.580,-17.500|FS:790,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:251.360,195.180,-17.500|FS:300,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:251.980,194.380,-17.500|FS:1020,0|WCO:103.000,103.000,-17.000|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.080,194.360,-17.500|FS:1740,0|Ov:100,100,100|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.080,195.160,-17.500|FS:1800,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.080,196.640,-17.500|FS:1164,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.080,198.480,-17.500|FS:444,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.080,199.880,-17.500|FS:517,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.080,200.540,-17.500|FS:919,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:252.500,200.580,-17.500|FS:157,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:253.380,200.580,-17.500|FS:877,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:253.660,200.480,-17.500|FS:1717,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:253.660,199.720,-17.500|FS:1306,0|WCO:103.000,103.000,-17.000|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:253.660,198.180,-17.500|FS:657,0|Ov:100,100,100|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:253.660,196.640,-17.500|FS:174,0|SD:35.57,/sd/LifeSpring Logo.gcode> <Run|MPos:253.660,195.860,-17.500|FS:0,0|SD:35.57,/sd/LifeSpring Logo.gcode> [MSG:INFO: ALARM: Soft Limit] ALARM:2 Soft limit alarm. G-code motion target exceeds machine travel. Machine position retained. Alarm may be safely unlocked, click the Reset Button. <Idle|MPos:253.660,195.740,-17.500|FS:0,0|SD:35.70,/sd/LifeSpring Logo.gcode> [GC:G2 G54 G17 G21 G90 G94 M5 M9 T0 F1800 S24000] [MSG:ERR: Reset to continue] <Alarm|MPos:253.660,195.740,-17.500|FS:0,0|SD:36.99,/sd/LifeSpring Logo.gcode> [MSG:INFO: WebUI: Request from 192.168.0.2]
