Hi,
Here is my build: Toolmaker build from germany
My machine travel is 50x115cm, so the X-belts are pretty long. When I tightend these, I noticed that they easily expand a few mm.
I aim for high precision or at least good repeatability.
But my parts dimensions at the first test cuts where all a bit too large, in both direction (X/Y) and on outside and inside contours.
To exclude the flexing of the tubes in my tests, I did a roughning pass first with 0.3mm extra and then a finishing pass. So I got a minimum deflection of the machine
I also played a bit with reducing the tool diameter, but I didnt get better.
Then I got it: Actually the stretch of the belt needs to be compensated.
So I recalculated the steps per mm and came out at around 199 steps per mm. Since then I got really precise parts, tolerance lower then 5/100mm at a length of 200mm.
The formula is: new steps/mm=(desired length/actual length)*actual steps/mm.
Works perfect now, even on my big machine and with high cutting forces.
The next days I will test the accuracy at longer distances.
I also got the core of my machine perfectly square. At least in the area I made my tests I got perfect 90° cuts.
I did the squaring of the machine as following:
I put the 2 tubes in the core but did not put it on the frame, yet.
I adjusted the angle as described in the squaring section with the help of a precise 90° tool square. Because I could move the rails freely, this gives much better feeling of the tension and you can set the angle without the influence of the trucks.
In my understanding, having the core rails perfectly perpendicular is much more important then having them parallel to the frame.
With the described method in the manual, I did not get it that good.
@vicious1 what do you think, maybe this can be updated in the manual? The only thing you need is a 90° angle, but this doesnt need to be a tool sqare at all. Because of the offset of the tube its not so easy to check, but if you aim over the square and move your head in a position that only a small lightgap is visibible between rail and square, you can get this really accurate. Good backlight helps.
Another thing is, I checked the bow of every tube and put the bend up, so this does not influence my XY-accuracy.
Also my very rigid frame helps a lot.
Is that common to adjust the steps per mm? I havent found anything similar.
I read its not recommended to use steel reinforced belts…for what reason? I think these flex less then the fiberglas ones.
Ciau,
Stefan
