Advice on Wiring Lengths
Hi all,
I’m just able to start my build, which is DIY printed and local sourced (I’m in Europe). This means I’ll be doing my own wiring also. I haven’t seen much covered in terms of wiring loom requirements. I’m aiming to build a full size 8x4 build, so I’m looking for guidance on wiring lengths when it comes to end stops and motor wiring?
Any pointers would be great!
Thanks,
Tom
The extensions in the Kit are 1.5m long and they are just a little bit too long for a full sheet built. So if you can find some extensions like that in your area they make it real easy
I was intrigued to learn that if the controller is on the x minimum side, no extensions for the y or z motor or endstops in the yz plate are needed, just extensions for the xmax yz plate z1 and y1 motors and endstops and the x motor endstop and touch plate.
Placing the controller in the center requires all of them to be extended.
The v1 cables are a bit long for a full sheet build, but better to have a little extra than not enough.
I am from Europe as well, and the only good extensions are from Ryan… :sweat_smile:
Then may as well get the whole kit. Or at minimum the XZ plates while your paying for the shipping lol
Oh yeah, those can only be bought from Ryan or you can cut them yourself later. :slightly_smiling_face:
