advice for squaring everything up
any advice or Jigs for squaring the MPCNC?
I used 1-2-3 blocks for setting height. I am struggling with a good place to take diagonal measurements from on the posts to be consistent and accurate. I am thinking of using a loop of string around the posts…
as always thanks in advance
I use an inner point, and an outer corner to take the measurement. The parts are symmetric with the bolt hole pattern OD. Lets you get a real good clear number.
