I am on the step where you add the LR Core to the beam. The instructions say “Add the LR-Core to the beam and set the tension of the lower two bolts” but it seems after tightening the bolt the whole LR Core is super loose on the beams. I made a video but I cant seem to paste links here.
That is just for the picture.
The video it is right. The rails do look odd in the braces through. I suspect they are the wrong diameter, or the braces are the wrong set for the rails. The Core is universal, so if it isn’t the rails or braces it is printer calibration.
You either need to get 1" OD tubing (not Conduit). Or print the right braces for what you have. Please measure your rails Outside diameter, Conduit is sold by INSIDE diamter.
