Hello, I’ve got an 8w diode Acan laser I’d like to put on my CNC. https//imgur.com/a/6j0Hu40
Am I right in assuming I can take the 3 wire off the current board (the controller not ths laser board) and put it on my Rambo board? Using the MX2 pins +, -, and 45 for the one that’s currently labeled “S”.
What do I need to change in the Marlin firmware and is there anything I need to do in Fusion360 to use the laser or am I better using a different program?
So many questions haha. Any help is appreciated. Thank you!
Ok, I updated the firmware on the RAMBo board un-commenting #define SPINDLE_LASER_ENABLE. The ACAN laser I’m using is 12v so I’ve got that wired to FAN 0. I have the control pin from the laser wired to pin 45 on RAMBo. pins_Rambo.h has 45 listed as the PMW pin.
I used ImagetoGcode to write some code and it seems like everything is fine except it’s not controlling the power of the laser. the gantry moves as I would expect. An M106 command starts the laser at full blast including the cooling fan on it. Repertier host throws an error when it sees an S** command.
Also, turning M106 without running a gcode file turns the laser on full blast. It seems to me it should start the laser cooling fan but not the laser itself without some sort of signal.
I’m assuming I’m doing something wrong with the control pin.
The laser should NOT be getting power through your Rambo. It should have a dedicated plus and minus wire for power and should be on. The cooling fan should be on full speed the entire time. I could be reading your message wrong but it sounds like the laser is powered up only when you use M106. That is not right.
Then you should have the control wires going from the Rambo to the TTL pins on the laser. That is what should control the on/off and brightness of the laser.
