7 Inch Android 4.4x tablets
All,
A friend had these two tablets and doesn’t want them anymore. They are older tablets but should work fine with Jackpot tablet controllers.
The white one is a Samsung Tab 3 Lite (model SM-t110) with 8GB of storage. Android 4.4.2 very clean and comes with a neoprene sleeve.
The black one is Dell Venue 7 (model 3740) with 16GB of storage. this is a tablet that uses an Intel Atom for the processor. Android 4.4.4, also very clean with neoprene sleeve.
I’d like to get $25 for each, plus shipping, and each one can easily fit in a USPS small flat rate box, so shipping in the US is less than $10.
Let me know if you’re interested in one of them.
Mike B.
Those look pretty sweet as a controller. The 10" I have is a bit big, so I figure a 7-8" would be ideal.
No takers?
Let’s give it a bit more time. If no one steps up I will take them. These seem perfect for a Jackpot board. I can easily make use of them.
I just tried to use these to connect to the Jackpot and found that the installed version(s) of Android may not support the AP mode on the board. I’ll do a little more research, but for the moment I can’t recommend these for tablet controllers with the Jackpot.
Symptoms are that connecting through the WiFi as a router(SSID = FluidNC) results in two or three different behaviors depending on the tablet/Android version. I also can get an iPad to connect, but with yet another behavior.
I guess I’m not quite sure if the AP or STA/AP mode will work better. USB is fine.
I’ll get back as soon as I figure out if it is my setup, or the tablet(s)’ limitation.
Mike
Hmmm, I would think AP would be no problem, but that is a very old version of android. That is a good data point.
Android often has conniptions about connecting to wifi where there is no DNS resolution (No Internet) available.
I used to have tablets connect to a wifi sporce without Internet (Only supposed to access a corporate network to be able to get to a web service for the Inventory system) and I had to give ot a return for a couple of DNS names or else the tablets would drop the network. Pretty sure I just had it return 127.0.0.1 for google.com, but I remember needing a couple more names so the tablet thought it had Internet. I remeber bei g quite annoyed at the idea of having to give something better than a tablet to the warehouse guys, so I watched traffic on port 53 using wireshark.
Do the tablets connect to the internet via a regular home wifi network without issues? If so, I would be interested in the black one.
@aeversme ,
Yes they connect just fine, here is the black one connected and showing the forum:
Mike
Nice. I’ll take the black one. Let me know how to get money to you.
@aeversme
Private message sent.
MB
