4x8 build LR3
Build started with buying the parts off a forum member who didnt have time to build it.
Quickly learned that there were diffrent size brackets and 1in OD pipe was impossible to find around me. After a few more purchases i was setup and ready to go.
With some saw horses and quickly built table ended up working out pretty good.
Leveled the MDF and got a quick understanding of the limitations of a trim router and a fat bit… three makitas later i was level. Got a FDM printer also to help complement any “upgrades”.
After scraping my idea to replace a makita with a bigger boy (metabo 12vc) this 4th makita is still going strong.
Remember mistakes create learning opportunities. Makita service center also cant be fioled easily
Got my first real cut going now
  1. How the f… do you destroy three Makita?
  2. You should use my improved dust shoe instead of risking getting your brush tangled in the Makita. :stuck_out_tongue:
Funny you saw that because thats why one of them blew up. Thats was the third one.
First one was preforming amazing though ultralight mdf with the 1.25in surfacing bit. Sadly i didnt put anything in the middle of the spoilboard so it bowed up in the middle. Swapped to regular mdf ran it with the same gcode and learned real quick how much denser it was. It smoked the router before half a pass.
Second one i shallowed it out to make off less per pass and after a few passes it melted the PLA from heat and dropped into the MDF creating a gash and a other blown motor.
All were my fault but I just replaced the holders with PETG so should be more protected against heat. Also make a bigger one to try out my larger router incase i need to surface a brand new board again.
Overall moral of the story is to setup a good base so you dont need alot of surfacing passes.
And/Or…don’t swing a 1.25" bit with a trim router. 1/4-1/2" is really good for this and you can move fast. A smaller bit also leaves less scalloping from a not perfect tram, so easier to adjust for.
Glad to have another full sized LR around here!
That sounds like a safer idea, ill grab a smaller surfacing bit.
Any chance to integrate the XYZ Touch Probe Plus - OpenBuilds Part Store
Looks like it makes it super easy to zero on the material no matter placement.
Should the 0,0 be aligned with the edge of the wood or half over or fully off the corner?
I used a dovetail bit. I ran it to the extremes of my machine. Just be careful not to create a swimming pool that will make material placement harder.
Update everything is getting better with some tuning.
Dovetail bit works great :+1:
New plastic guard attachment works wonders.
Now just gotta figure out how to get strait cross cuts.
Uploading: 20230803_223635.jpg…
How bad are they now? Feeds and speeds, what endmill? Did you use a finishing pass?
Im using spetools w02003 (1/4in compression)with its default feed and speed. Makita set to 3.5ish. No finishing pass but I essentially do that with a w02004 (1/8in compression). Here is a photo prior to the W02004 pass.
Could be I have it climbing instead of conventional so maybe that caused it idk. Still learning the cam tips and tricks.
Is that deep enough for a compression bit? What are the default feeds and speeds? It looks like the feedrate is too fast. I have never seen such crazy wandering without breaking a bit.
Always use a finishing pass, and I don’t see any reason to change bit to do that unless you are trying to get tighter corners. Just do a 10%-15% finishing pass with a 10% slower feed rate for the roughing and see if that fixes it.
The chips are good but for these machines they are a bit large. So you need a smaller bite.
That’s pretty fast.
MDF = 110 mm/s
Softwood = 93 mm/s
Hardwood = 76 mm/s
All at 6.35mm DOC. That’s a LOT. Even half of that is a lot. I have that same bit and I think I run it at 20 mm/s at 5mm DOC.
Might be a good idea to run you some test cuts at various speed / DOC and see where it ends up happiest. I know I need to do that for a lot of my bits.
For w02004
I think its about 53 mm/sec
For 02003
Around 84 mm/sec
I set it to 5 passes to cut through
I will cut the speeds down but do i keep the 5 passes or reduce it to normal 3
Cut the spindle speed in half and the feedrate in half and you will still have the same chipload. From there go a bit less on the depth of cut.
Once it is doing what you want you can speed back up with each test cut.
That is too fast and you now know your machine can’t handle it, but it is pretty close since it didn’t skip steps or break a bit, or burn the wood.
Just to add to it plywood is slower than the list because of the glue. Crappy ply is the slowest with the most glue, something like marine or baltic birch ply can go faster since it is less glue.
Also…now that I am thinking about it you might be trying to exceed the firmware max speeds so you might have to slow down considerably to see results. The max speed is either 30 or 50mm/s. You can check on the skrpro’s screen. You can increase the max speed but make sure you understand how your machine cuts first.
Awesome, thanks for the help guys.
I am running marlin v1 rapid post processor for vcarve. 24v power adapter
I slowed it all down with the 1/8in compression bit
Running now at 65 inch/min speed 3
I just found a makita cnc speed calculator so ill test it out.
That looks far better. If you want that speed back you can keep pushing it until you hear or see a difference.
50 mm/s I believe. Had to bump mine up the other day doing the long surfacing runs so it would come back faster lol
Upgraded to LR4 with a new table
What do you think? How does it compare.
