Still working my way through this, slowly. I have created a G code file through Repetier. Sent the file to the SD card. When I run the G code the machine moves in both X and Y directions, very quickly, then stops. I get a Error 36. I have looked it up (Alarm and Error Codes | Wiki.js )only to find the error code but not what is causing it. Any help would be appreciated.
Equipment; MPCNC, Jackpot controller, FluidNC, Repetier software for G code conversion.
Did you start with the test crown?
We do not typically use repetier to make any gcode at all, you will need to be very careful using that.
Ryan,
Thanks for your reply. However, now I am more confused than ever. If not Repetier, than Is Estlcam the only other option? I have read through the Jackpot documentation and saw the Estlcam setup not aware that perhaps this is the only option. However, the software workflow document tells me I can use Repetier. Is there a document that would be specific to my components?
You are looking for CAM software.
I highly suggest you start with ESTLCAM you can use the free option as long as you would like. From there, the learning curve is significantly higher, and you can use just about any CAM program you want that can export GRBL compatible Gcode. ESTLCAM just happens to do 98% of what everyone needs with these machines and is as simple as CAM gets.
orob
July 3, 2024, 1:50am
5
When I started I remember being super confused by this. I just wanted this thing on the screen cut out. While the steps are relatively simple, there are many fine details that accompany the different steps or tasks. It is important to separate out the tasks you are trying to accomplish. Designing the part is CAD. Creating gcode is CAM. Sending gcode to the machine is a sender program. Some senders try to do cam and some cam programs try to send. Other programs try to do it all. Just because estlcam can send doesn’t mean it has to be the sender. Some cncs read gcode directly from an SD card and don’t need a sender (like the ones running marlin). The list of software options below is not complete, but categorizes some of the ones that are out there.
Cad - fusion 360, nx, soludworks, SketchUp. Tinkercad, freecad, (not an exhaustive list), or even inkscape or coreldraw for svg generation.
Cad+ cam: fusion, freecad, blender, inkscape, kiri:moto
Cam - estlcam, carbide create
Cam +sender: estlcam, lightburn, carbide create
Sender - cncjs. repetier, fluidnc,
All in one: light burn for laser and soon, millmage.
Some software packages try to do more than just one thing and are not compatible with all the versions of CNC firmware, so they don’t work well in all instances. Ask 5 people around here how they run their workflow and the answers will vary based on design experience and what they are making. For a year I did everything in inkscape except send… Then I tried estlcam and immediately stopped that madness. You may need to try a few things to see what you like or can tolerate, or you can go with the recommended tools.
This is a great place to learn! I still refer to it!
https://docs.v1e.com/tools/milling-basics/
Basically the reason you are getting that error is that Repetier Host doesn’t make Grbl friendly G-code. That document you referred to is for the older workflow that was using Repetier Host creating G-Code for a Marlin Firmware based controller board. The new Jackpot controller runs FluidNC, which, at the core, is Grbl based. While G-code is generally similar, Marlin used A LOT of commands that Grbl doesn’t understand, and you get that error.
spinorose
(Spinorose)
September 9, 2024, 2:14pm
8
I have carbide create pro and I when I save the gcode it saves it as the NC . what do I need to do get the gcode to run on my marlin lowrider 3 . Thanks
ebbels
(Eetu)
September 9, 2024, 2:42pm
9
You can change .NC files into .gcode file just overwriting the file name like “program.NC” to “program.gcode”
But there might be differences between marlin gcode and carbides gcode. For examble some Mcodes.
spinorose
(Spinorose)
September 9, 2024, 5:04pm
10
its not allow me to rename the extenstion to .gcode
vicious1
(Ryan)
September 9, 2024, 5:44pm
11
It is a text file you can just change it after you save it.
Depends on the board though, marlin does not “see” .nc, but the jackpot is fine with them.
The more important part that Eetu is getting at is what is called post processing and not all Gcode files are in the same language. So I have never used carbide create and I am not sure with it supports fluidnc or Marlin directly. So it is spitting out a questionable file.
Any reason not to try the recommended estlcam from the milling basics page, or the test crown?
DougJoseph
(Doug Joseph (design8studio))
September 9, 2024, 6:03pm
12
Regardless of whether the authoring program allows it, you can just rename it in your File Explorer in your operating system.
DougJoseph
September 9, 2024, 6:07pm
13
Just wanted to say, I strongly second what Ryan is saying here. Start with the crown test download from here, which is precompiled gcode so you can test your machine and demonstrate that it’s complete and ready to go. Then, please try the recommended free trial of ESTLcam. You import a vector file (in either SVG or DXF format) and choose “hole” or “part” button for either inside or outside cuts, tell it which tool to use (may have to add a tool that matches your bit), and then click on each line you want cut, and tell it how deep to cut and whether to do a finishing pass, or holding tabs, etc. Then output the GCode file. Put that on SD card. (If using Jackpot control board from Ryan it can be sent to SD card via WIFI). On the V1E designed machine, just run the GCode file from the SD card.
spinorose
(Spinorose)
September 18, 2024, 11:05pm
14
so when I did the obvious change and add just two lines to turn
G90
M03 S24000
G92 X0 Y0 Z0
M106
G00 Z5.0000
G20
(Toolpath:...)
(Pocket To...)
M05
M0 ;T102
M03S10000
G0X10.6063Y3.2532Z0.3940
G1Z-0.0500F8.0
X10.5986Y3.2535F20.0
X10.5903Y3.2540
X10.5738Y3.2557
X10.5580Y3.2581
X10.5423Y3.2613
X10.5267Y3.2653
X10.5114Y3.2701
X10.4966Y3.2756
X10.4825Y3.2815
X10.4681Y3.2884
X10.4543Y3.2959
X10.4415Y3.3037
X10.4283Y3.3126
X10.4159Y3.3219
X10.4041Y3.3316
X10.3923Y3.3424
X10.3814Y3.3533
X10.3714Y3.3643
X10.3613Y3.3765
X10.3520Y3.3889
X10.3431Y3.4020
X10.3352Y3.4151
X10.3277Y3.4288
X10.3209Y3.4429
X10.3149Y3.4572
X10.3096Y3.4716
X10.3046Y3.4876
X10.3008Y3.5024
X10.2974Y3.5189
X10.2951Y3.5344
X10.2935Y3.5502
X10.2929Y3.5580
X10.2924Y3.5756
X10.2929Y3.5925
X10.2934Y3.6007
X10.2951Y3.6168
X10.2974Y3.6323
X10.3007Y3.6484
X10.3047Y3.6639
X10.3094Y3.6790
X10.3149Y3.6940
X10.3209Y3.7083
X10.3273Y3.7215
X10.3351Y3.7360
X10.3428Y3.7487
X10.3520Y3.7623
X10.3612Y3.7746
X10.3709Y3.7864
X10.3813Y3.7978
X10.3928Y3.8093
X10.4041Y3.8196
X10.4159Y3.8293
X10.4283Y3.8386
X10.4415Y3.8475
X10.4543Y3.8553
X10.4681Y3.8628
X10.4825Y3.8698
X10.4966Y3.8757
X10.5113Y3.8811
X10.5277Y3.8861
X10.5339Y3.8878
X10.5420Y3.8898
X10.5580Y3.8931
X10.5738Y3.8955
X10.5903Y3.8972
X10.5986Y3.8977
X10.6062Y3.8980
X10.6238
X10.6313Y3.8977
X10.6396Y3.8972
X10.6561Y3.8955
X10.6719Y3.8931
X10.6880Y3.8898
X10.6961Y3.8878
X10.7023Y3.8861
X10.7186Y3.8811
X10.7333Y3.8757
X10.7474Y3.8698
X10.7618Y3.8628
X10.7757Y3.8553
X10.7883Y3.8476
X10.8017Y3.8386
X10.8143Y3.8292
X10.8258Y3.8196
X10.8372Y3.8093
X10.8487Y3.7978
X10.8591Y3.7864
X10.8687Y3.7746
X10.8780Y3.7623
X10.8871Y3.7487
X10.8948Y3.7360
X10.9022Y3.7224
X10.9091Y3.7081
X10.9150Y3.6940
X10.9206Y3.6789
X10.9252Y3.6641
X10.9293Y3.6483
X10.9325Y3.6325
X10.9349Y3.6168
X10.9366Y3.6003
X10.9371Y3.5914
X10.9374Y3.5844
Y3.5667
X10.9371Y3.5598
X10.9365Y3.5502
X10.9349Y3.5344
X10.9325Y3.5187
X10.9292Y3.5028
X10.9253Y3.4873
X10.9204Y3.4716
X10.9150Y3.4572
X10.9089Y3.4425
X10.9024Y3.4291
X10.8948Y3.4151
X10.8868Y3.4020
X10.8780Y3.3889
X10.8687Y3.3765
X10.8586Y3.3643
X10.8486Y3.3533
X10.8377Y3.3424
X10.8258Y3.3316
X10.8143Y3.3220
X10.8011Y3.3122
X10.7951Y3.3081
X10.7888Y3.3039
X10.7757Y3.2959
X10.7618Y3.2884
X10.7474Y3.2815
X10.7333Y3.2756
X10.7185Y3.2701
X10.7033Y3.2653
X10.6877Y3.2613
X10.6719Y3.2581
X10.6561Y3.2557
X10.6396Y3.2540
X10.6313Y3.2535
X10.6237Y3.2532
X10.6150Y3.2531
X10.6063Y3.2532
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.5903Y3.2540
X10.5738Y3.2557
X10.5580Y3.2581
X10.5423Y3.2613
X10.5267Y3.2653
X10.5114Y3.2701
X10.4966Y3.2756
X10.4825Y3.2815
X10.4681Y3.2884
X10.4543Y3.2959
X10.4415Y3.3037
X10.4283Y3.3126
X10.4159Y3.3219
X10.4041Y3.3316
X10.3923Y3.3424
X10.3814Y3.3533
X10.3714Y3.3643
X10.3613Y3.3765
X10.3520Y3.3889
X10.3431Y3.4020
X10.3352Y3.4151
X10.3277Y3.4288
X10.3209Y3.4429
X10.3149Y3.4572
X10.3096Y3.4716
X10.3046Y3.4876
X10.3008Y3.5024
X10.2974Y3.5189
X10.2951Y3.5344
X10.2935Y3.5502
X10.2929Y3.5580
X10.2924Y3.5756
X10.2929Y3.5925
X10.2934Y3.6007
X10.2951Y3.6168
X10.2974Y3.6323
X10.3007Y3.6484
X10.3047Y3.6639
X10.3094Y3.6790
X10.3149Y3.6940
X10.3209Y3.7083
X10.3273Y3.7215
X10.3351Y3.7360
X10.3428Y3.7487
X10.3520Y3.7623
X10.3612Y3.7746
X10.3709Y3.7864
X10.3813Y3.7978
X10.3928Y3.8093
X10.4041Y3.8196
X10.4159Y3.8293
X10.4283Y3.8386
X10.4415Y3.8475
X10.4543Y3.8553
X10.4681Y3.8628
X10.4825Y3.8698
X10.4966Y3.8757
X10.5113Y3.8811
X10.5277Y3.8861
X10.5339Y3.8878
X10.5420Y3.8898
X10.5580Y3.8931
X10.5738Y3.8955
X10.5903Y3.8972
X10.5986Y3.8977
X10.6062Y3.8980
X10.6238
X10.6313Y3.8977
X10.6396Y3.8972
X10.6561Y3.8955
X10.6719Y3.8931
X10.6880Y3.8898
X10.6961Y3.8878
X10.7023Y3.8861
X10.7186Y3.8811
X10.7333Y3.8757
X10.7474Y3.8698
X10.7618Y3.8628
X10.7757Y3.8553
X10.7883Y3.8476
X10.8017Y3.8386
X10.8143Y3.8292
X10.8258Y3.8196
X10.8372Y3.8093
X10.8487Y3.7978
X10.8591Y3.7864
X10.8687Y3.7746
X10.8780Y3.7623
X10.8871Y3.7487
X10.8948Y3.7360
X10.9022Y3.7224
X10.9091Y3.7081
X10.9150Y3.6940
X10.9206Y3.6789
X10.9252Y3.6641
X10.9293Y3.6483
X10.9325Y3.6325
X10.9349Y3.6168
X10.9366Y3.6003
X10.9371Y3.5914
X10.9374Y3.5844
Y3.5667
X10.9371Y3.5598
X10.9365Y3.5502
X10.9349Y3.5344
X10.9325Y3.5187
X10.9292Y3.5028
X10.9253Y3.4873
X10.9204Y3.4716
X10.9150Y3.4572
X10.9089Y3.4425
X10.9024Y3.4291
X10.8948Y3.4151
X10.8868Y3.4020
X10.8780Y3.3889
X10.8687Y3.3765
X10.8586Y3.3643
X10.8486Y3.3533
X10.8377Y3.3424
X10.8258Y3.3316
X10.8143Y3.3220
X10.8011Y3.3122
X10.7951Y3.3081
X10.7888Y3.3039
X10.7757Y3.2959
X10.7618Y3.2884
X10.7474Y3.2815
X10.7333Y3.2756
X10.7185Y3.2701
X10.7033Y3.2653
X10.6877Y3.2613
X10.6719Y3.2581
X10.6561Y3.2557
X10.6396Y3.2540
X10.6313Y3.2535
X10.6237Y3.2532
X10.6150Y3.2531
X10.6063Y3.2532
G0Z-0.0502
Z0.3940
X10.4497Y3.7138
G1Z-0.0500F8.0
X10.4434Y3.7061F20.0
X10.4370Y3.6972
X10.4316Y3.6888
X10.4263Y3.6798
X10.4213Y3.6702
X10.4171Y3.6610
X10.4132Y3.6513
X10.4096Y3.6411
X10.4067Y3.6309
X10.4042Y3.6207
X10.4022Y3.6098
X10.4008Y3.5993
X10.3998Y3.5882
X10.3995Y3.5740
X10.3997Y3.5661
X10.4004Y3.5552
X10.4018Y3.5443
X10.4035Y3.5339
X10.4059Y3.5231
X10.4087Y3.5131
X10.4120Y3.5030
X10.4159Y3.4930
X10.4202Y3.4835
X10.4246Y3.4744
X10.4300Y3.4650
X10.4356Y3.4563
X10.4413Y3.4480
X10.4479Y3.4396
X10.4545Y3.4318
X10.4616Y3.4242
X10.4689Y3.4172
X10.4767Y3.4103
X10.4847Y3.4039
X10.4934Y3.3977
X10.5018Y3.3922
X10.5108Y3.3869
X10.5202Y3.3820
X10.5299Y3.3776
X10.5393Y3.3738
X10.5495Y3.3703
X10.5597Y3.3673
X10.5699Y3.3648
X10.5808Y3.3628
X10.5913Y3.3614
X10.6024Y3.3605
X10.6165Y3.3601
X10.6244Y3.3603
X10.6354Y3.3611
X10.6463Y3.3624
X10.6567Y3.3642
X10.6675Y3.3666
X10.6775Y3.3693
X10.6876Y3.3727
X10.6976Y3.3766
X10.7069Y3.3806
X10.7164Y3.3854
X10.7256Y3.3906
X10.7343Y3.3962
X10.7426Y3.4019
X10.7512Y3.4086
X10.7587Y3.4151
X10.7661Y3.4220
X10.7734Y3.4295
X10.7803Y3.4374
X10.7867Y3.4454
X10.7929Y3.4541
X10.7984Y3.4624
X10.8037Y3.4715
X10.8087Y3.4811
X10.8129Y3.4902
X10.8168Y3.4999
X10.8203Y3.5102
X10.8233Y3.5204
X10.8257Y3.5305
X10.8278Y3.5414
X10.8292Y3.5520
X10.8301Y3.5630
X10.8305Y3.5772
X10.8303Y3.5850
X10.8295Y3.5960
X10.8282Y3.6069
X10.8264Y3.6174
X10.8240Y3.6281
X10.8213Y3.6381
X10.8179Y3.6482
X10.8140Y3.6583
X10.8098Y3.6678
X10.8053Y3.6768
X10.8000Y3.6862
X10.7944Y3.6950
X10.7887Y3.7032
X10.7820Y3.7118
X10.7755Y3.7194
X10.7683Y3.7270
X10.7610Y3.7341
X10.7532Y3.7409
X10.7454Y3.7472
X10.7365Y3.7535
X10.7281Y3.7590
X10.7191Y3.7643
X10.7095Y3.7693
X10.7004Y3.7735
X10.6907Y3.7774
X10.6804Y3.7809
X10.6702Y3.7839
X10.6601Y3.7864
X10.6492Y3.7884
X10.6386Y3.7898
X10.6276Y3.7907
X10.6134Y3.7911
X10.6056Y3.7909
X10.5946Y3.7902
X10.5837Y3.7888
X10.5732Y3.7870
X10.5625Y3.7846
X10.5525Y3.7819
X10.5424Y3.7785
X10.5323Y3.7746
X10.5228Y3.7704
X10.5138Y3.7659
X10.5044Y3.7606
X10.4956Y3.7550
X10.4874Y3.7493
X10.4789Y3.7427
X10.4712Y3.7361
X10.4635Y3.7288
X10.4565Y3.7217
X10.4497Y3.7138
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.4370Y3.6972
X10.4316Y3.6888
X10.4263Y3.6798
X10.4213Y3.6702
X10.4171Y3.6610
X10.4132Y3.6513
X10.4096Y3.6411
X10.4067Y3.6309
X10.4042Y3.6207
X10.4022Y3.6098
X10.4008Y3.5993
X10.3998Y3.5882
X10.3995Y3.5740
X10.3997Y3.5661
X10.4004Y3.5552
X10.4018Y3.5443
X10.4035Y3.5339
X10.4059Y3.5231
X10.4087Y3.5131
X10.4120Y3.5030
X10.4159Y3.4930
X10.4202Y3.4835
X10.4246Y3.4744
X10.4300Y3.4650
X10.4356Y3.4563
X10.4413Y3.4480
X10.4479Y3.4396
X10.4545Y3.4318
X10.4616Y3.4242
X10.4689Y3.4172
X10.4767Y3.4103
X10.4847Y3.4039
X10.4934Y3.3977
X10.5018Y3.3922
X10.5108Y3.3869
X10.5202Y3.3820
X10.5299Y3.3776
X10.5393Y3.3738
X10.5495Y3.3703
X10.5597Y3.3673
X10.5699Y3.3648
X10.5808Y3.3628
X10.5913Y3.3614
X10.6024Y3.3605
X10.6165Y3.3601
X10.6244Y3.3603
X10.6354Y3.3611
X10.6463Y3.3624
X10.6567Y3.3642
X10.6675Y3.3666
X10.6775Y3.3693
X10.6876Y3.3727
X10.6976Y3.3766
X10.7069Y3.3806
X10.7164Y3.3854
X10.7256Y3.3906
X10.7343Y3.3962
X10.7426Y3.4019
X10.7512Y3.4086
X10.7587Y3.4151
X10.7661Y3.4220
X10.7734Y3.4295
X10.7803Y3.4374
X10.7867Y3.4454
X10.7929Y3.4541
X10.7984Y3.4624
X10.8037Y3.4715
X10.8087Y3.4811
X10.8129Y3.4902
X10.8168Y3.4999
X10.8203Y3.5102
X10.8233Y3.5204
X10.8257Y3.5305
X10.8278Y3.5414
X10.8292Y3.5520
X10.8301Y3.5630
X10.8305Y3.5772
X10.8303Y3.5850
X10.8295Y3.5960
X10.8282Y3.6069
X10.8264Y3.6174
X10.8240Y3.6281
X10.8213Y3.6381
X10.8179Y3.6482
X10.8140Y3.6583
X10.8098Y3.6678
X10.8053Y3.6768
X10.8000Y3.6862
X10.7944Y3.6950
X10.7887Y3.7032
X10.7820Y3.7118
X10.7755Y3.7194
X10.7683Y3.7270
X10.7610Y3.7341
X10.7532Y3.7409
X10.7454Y3.7472
X10.7365Y3.7535
X10.7281Y3.7590
X10.7191Y3.7643
X10.7095Y3.7693
X10.7004Y3.7735
X10.6907Y3.7774
X10.6804Y3.7809
X10.6702Y3.7839
X10.6601Y3.7864
X10.6492Y3.7884
X10.6386Y3.7898
X10.6276Y3.7907
X10.6134Y3.7911
X10.6056Y3.7909
X10.5946Y3.7902
X10.5837Y3.7888
X10.5732Y3.7870
X10.5625Y3.7846
X10.5525Y3.7819
X10.5424Y3.7785
X10.5323Y3.7746
X10.5228Y3.7704
X10.5138Y3.7659
X10.5044Y3.7606
X10.4956Y3.7550
X10.4874Y3.7493
X10.4789Y3.7427
X10.4712Y3.7361
X10.4635Y3.7288
X10.4565Y3.7217
X10.4497Y3.7138
G0Z-0.0502
Z0.3940
X10.6063Y5.2532
G1Z-0.0500F8.0
X10.5986Y5.2535F20.0
X10.5903Y5.2540
X10.5738Y5.2557
X10.5580Y5.2581
X10.5423Y5.2613
X10.5267Y5.2653
X10.5114Y5.2701
X10.4966Y5.2756
X10.4825Y5.2815
X10.4681Y5.2884
X10.4543Y5.2959
X10.4415Y5.3037
X10.4283Y5.3126
X10.4159Y5.3219
X10.4041Y5.3316
X10.3928Y5.3419
X10.3813Y5.3534
X10.3710Y5.3647
X10.3614Y5.3763
X10.3520Y5.3889
X10.3430Y5.4023
X10.3353Y5.4149
X10.3276Y5.4292
X10.3209Y5.4429
X10.3149Y5.4572
X10.3096Y5.4716
X10.3047Y5.4874
X10.3009Y5.5021
X10.2974Y5.5189
X10.2951Y5.5344
X10.2935Y5.5502
X10.2929Y5.5580
X10.2924Y5.5756
X10.2929Y5.5925
X10.2934Y5.6007
X10.2951Y5.6168
X10.2974Y5.6323
X10.3007Y5.6483
X10.3047Y5.6639
X10.3094Y5.6790
X10.3149Y5.6940
X10.3209Y5.7083
X10.3273Y5.7215
X10.3351Y5.7360
X10.3428Y5.7487
X10.3520Y5.7623
X10.3613Y5.7747
X10.3710Y5.7865
X10.3813Y5.7978
X10.3928Y5.8093
X10.4039Y5.8194
X10.4159Y5.8293
X10.4285Y5.8387
X10.4415Y5.8475
X10.4546Y5.8555
X10.4680Y5.8627
X10.4760Y5.8667
X10.4817Y5.8694
X10.4900Y5.8730
X10.4961Y5.8755
X10.5113Y5.8811
X10.5277Y5.8861
X10.5339Y5.8878
X10.5420Y5.8898
X10.5580Y5.8931
X10.5738Y5.8955
X10.5903Y5.8972
X10.5986Y5.8977
X10.6062Y5.8980
X10.6238
X10.6313Y5.8977
X10.6396Y5.8972
X10.6561Y5.8955
X10.6719Y5.8931
X10.6880Y5.8898
X10.6961Y5.8878
X10.7023Y5.8861
X10.7186Y5.8811
X10.7338Y5.8755
X10.7400Y5.8730
X10.7482Y5.8694
X10.7539Y5.8667
X10.7620Y5.8627
X10.7754Y5.8555
X10.7883Y5.8476
X10.8019Y5.8384
X10.8138Y5.8295
X10.8260Y5.8194
X10.8372Y5.8093
X10.8487Y5.7978
X10.8590Y5.7865
X10.8687Y5.7747
X10.8780Y5.7623
X10.8871Y5.7487
X10.8948Y5.7360
X10.9022Y5.7224
X10.9091Y5.7081
X10.9150Y5.6940
X10.9206Y5.6789
X10.9252Y5.6641
X10.9293Y5.6483
X10.9325Y5.6325
X10.9349Y5.6168
X10.9366Y5.6003
X10.9371Y5.5914
X10.9374Y5.5844
Y5.5667
X10.9371Y5.5598
X10.9365Y5.5502
X10.9349Y5.5344
X10.9325Y5.5187
X10.9292Y5.5028
X10.9252Y5.4872
X10.9204Y5.4716
X10.9150Y5.4572
X10.9091Y5.4431
X10.9022Y5.4288
X10.8946Y5.4149
X10.8870Y5.4023
X10.8780Y5.3889
X10.8685Y5.3763
X10.8589Y5.3647
X10.8487Y5.3534
X10.8372Y5.3419
X10.8258Y5.3316
X10.8143Y5.3220
X10.8017Y5.3126
X10.7883Y5.3036
X10.7757Y5.2959
X10.7618Y5.2884
X10.7474Y5.2815
X10.7333Y5.2756
X10.7185Y5.2701
X10.7033Y5.2653
X10.6877Y5.2613
X10.6719Y5.2581
X10.6561Y5.2557
X10.6396Y5.2540
X10.6313Y5.2535
X10.6237Y5.2532
X10.6150Y5.2531
X10.6063Y5.2532
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.5903Y5.2540
X10.5738Y5.2557
X10.5580Y5.2581
X10.5423Y5.2613
X10.5267Y5.2653
X10.5114Y5.2701
X10.4966Y5.2756
X10.4825Y5.2815
X10.4681Y5.2884
X10.4543Y5.2959
X10.4415Y5.3037
X10.4283Y5.3126
X10.4159Y5.3219
X10.4041Y5.3316
X10.3928Y5.3419
X10.3813Y5.3534
X10.3710Y5.3647
X10.3614Y5.3763
X10.3520Y5.3889
X10.3430Y5.4023
X10.3353Y5.4149
X10.3276Y5.4292
X10.3209Y5.4429
X10.3149Y5.4572
X10.3096Y5.4716
X10.3047Y5.4874
X10.3009Y5.5021
X10.2974Y5.5189
X10.2951Y5.5344
X10.2935Y5.5502
X10.2929Y5.5580
X10.2924Y5.5756
X10.2929Y5.5925
X10.2934Y5.6007
X10.2951Y5.6168
X10.2974Y5.6323
X10.3007Y5.6483
X10.3047Y5.6639
X10.3094Y5.6790
X10.3149Y5.6940
X10.3209Y5.7083
X10.3273Y5.7215
X10.3351Y5.7360
X10.3428Y5.7487
X10.3520Y5.7623
X10.3613Y5.7747
X10.3710Y5.7865
X10.3813Y5.7978
X10.3928Y5.8093
X10.4039Y5.8194
X10.4159Y5.8293
X10.4285Y5.8387
X10.4415Y5.8475
X10.4546Y5.8555
X10.4680Y5.8627
X10.4760Y5.8667
X10.4817Y5.8694
X10.4900Y5.8730
X10.4961Y5.8755
X10.5113Y5.8811
X10.5277Y5.8861
X10.5339Y5.8878
X10.5420Y5.8898
X10.5580Y5.8931
X10.5738Y5.8955
X10.5903Y5.8972
X10.5986Y5.8977
X10.6062Y5.8980
X10.6238
X10.6313Y5.8977
X10.6396Y5.8972
X10.6561Y5.8955
X10.6719Y5.8931
X10.6880Y5.8898
X10.6961Y5.8878
X10.7023Y5.8861
X10.7186Y5.8811
X10.7338Y5.8755
X10.7400Y5.8730
X10.7482Y5.8694
X10.7539Y5.8667
X10.7620Y5.8627
X10.7754Y5.8555
X10.7883Y5.8476
X10.8019Y5.8384
X10.8138Y5.8295
X10.8260Y5.8194
X10.8372Y5.8093
X10.8487Y5.7978
X10.8590Y5.7865
X10.8687Y5.7747
X10.8780Y5.7623
X10.8871Y5.7487
X10.8948Y5.7360
X10.9022Y5.7224
X10.9091Y5.7081
X10.9150Y5.6940
X10.9206Y5.6789
X10.9252Y5.6641
X10.9293Y5.6483
X10.9325Y5.6325
X10.9349Y5.6168
X10.9366Y5.6003
X10.9371Y5.5914
X10.9374Y5.5844
Y5.5667
X10.9371Y5.5598
X10.9365Y5.5502
X10.9349Y5.5344
X10.9325Y5.5187
X10.9292Y5.5028
X10.9252Y5.4872
X10.9204Y5.4716
X10.9150Y5.4572
X10.9091Y5.4431
X10.9022Y5.4288
X10.8946Y5.4149
X10.8870Y5.4023
X10.8780Y5.3889
X10.8685Y5.3763
X10.8589Y5.3647
X10.8487Y5.3534
X10.8372Y5.3419
X10.8258Y5.3316
X10.8143Y5.3220
X10.8017Y5.3126
X10.7883Y5.3036
X10.7757Y5.2959
X10.7618Y5.2884
X10.7474Y5.2815
X10.7333Y5.2756
X10.7185Y5.2701
X10.7033Y5.2653
X10.6877Y5.2613
X10.6719Y5.2581
X10.6561Y5.2557
X10.6396Y5.2540
X10.6313Y5.2535
X10.6237Y5.2532
X10.6150Y5.2531
X10.6063Y5.2532
G0Z-0.0502
Z0.3940
X10.7532Y5.7409
G1Z-0.0500F8.0
X10.7454Y5.7472F20.0
X10.7365Y5.7535
X10.7281Y5.7590
X10.7191Y5.7643
X10.7098Y5.7692
X10.7004Y5.7735
X10.6904Y5.7775
X10.6804Y5.7809
X10.6705Y5.7839
X10.6598Y5.7865
X10.6492Y5.7884
X10.6386Y5.7898
X10.6276Y5.7907
X10.6134Y5.7911
X10.6056Y5.7909
X10.5946Y5.7902
X10.5837Y5.7888
X10.5732Y5.7870
X10.5628Y5.7848
X10.5522Y5.7818
X10.5424Y5.7785
X10.5326Y5.7748
X10.5228Y5.7705
X10.5136Y5.7658
X10.5044Y5.7606
X10.4956Y5.7550
X10.4874Y5.7493
X10.4789Y5.7427
X10.4712Y5.7361
X10.4635Y5.7288
X10.4565Y5.7217
X10.4497Y5.7138
X10.4434Y5.7061
X10.4370Y5.6972
X10.4315Y5.6886
X10.4264Y5.6799
X10.4213Y5.6702
X10.4171Y5.6610
X10.4131Y5.6512
X10.4096Y5.6412
X10.4067Y5.6307
X10.4042Y5.6207
X10.4022Y5.6098
X10.4008Y5.5993
X10.3998Y5.5882
X10.3995Y5.5740
X10.3997Y5.5661
X10.4004Y5.5552
X10.4018Y5.5443
X10.4035Y5.5339
X10.4059Y5.5231
X10.4087Y5.5131
X10.4120Y5.5030
X10.4159Y5.4930
X10.4202Y5.4835
X10.4246Y5.4744
X10.4300Y5.4650
X10.4356Y5.4563
X10.4413Y5.4480
X10.4479Y5.4396
X10.4545Y5.4318
X10.4616Y5.4242
X10.4689Y5.4172
X10.4765Y5.4104
X10.4849Y5.4038
X10.4934Y5.3977
X10.5018Y5.3922
X10.5108Y5.3869
X10.5202Y5.3820
X10.5296Y5.3777
X10.5396Y5.3737
X10.5493Y5.3703
X10.5597Y5.3672
X10.5702Y5.3648
X10.5805Y5.3628
X10.5917Y5.3614
X10.6024Y5.3605
X10.6165Y5.3601
X10.6244Y5.3603
X10.6354Y5.3611
X10.6459Y5.3623
X10.6570Y5.3642
X10.6672Y5.3665
X10.6775Y5.3693
X10.6878Y5.3728
X10.6973Y5.3764
X10.7071Y5.3807
X10.7164Y5.3854
X10.7256Y5.3906
X10.7343Y5.3962
X10.7426Y5.4019
X10.7509Y5.4084
X10.7589Y5.4153
X10.7661Y5.4220
X10.7734Y5.4295
X10.7803Y5.4374
X10.7867Y5.4454
X10.7929Y5.4541
X10.7984Y5.4624
X10.8037Y5.4715
X10.8087Y5.4811
X10.8129Y5.4902
X10.8168Y5.4999
X10.8203Y5.5102
X10.8233Y5.5204
X10.8257Y5.5305
X10.8278Y5.5414
X10.8292Y5.5520
X10.8301Y5.5630
X10.8305Y5.5772
X10.8303Y5.5850
X10.8295Y5.5960
X10.8282Y5.6069
X10.8264Y5.6174
X10.8240Y5.6281
X10.8213Y5.6380
X10.8179Y5.6483
X10.8141Y5.6581
X10.8098Y5.6678
X10.8053Y5.6768
X10.7999Y5.6863
X10.7945Y5.6948
X10.7887Y5.7032
X10.7820Y5.7118
X10.7755Y5.7194
X10.7683Y5.7270
X10.7610Y5.7341
X10.7532Y5.7409
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.7365Y5.7535
X10.7281Y5.7590
X10.7191Y5.7643
X10.7098Y5.7692
X10.7004Y5.7735
X10.6904Y5.7775
X10.6804Y5.7809
X10.6705Y5.7839
X10.6598Y5.7865
X10.6492Y5.7884
X10.6386Y5.7898
X10.6276Y5.7907
X10.6134Y5.7911
X10.6056Y5.7909
X10.5946Y5.7902
X10.5837Y5.7888
X10.5732Y5.7870
X10.5628Y5.7848
X10.5522Y5.7818
X10.5424Y5.7785
X10.5326Y5.7748
X10.5228Y5.7705
X10.5136Y5.7658
X10.5044Y5.7606
X10.4956Y5.7550
X10.4874Y5.7493
X10.4789Y5.7427
X10.4712Y5.7361
X10.4635Y5.7288
X10.4565Y5.7217
X10.4497Y5.7138
X10.4434Y5.7061
X10.4370Y5.6972
X10.4315Y5.6886
X10.4264Y5.6799
X10.4213Y5.6702
X10.4171Y5.6610
X10.4131Y5.6512
X10.4096Y5.6412
X10.4067Y5.6307
X10.4042Y5.6207
X10.4022Y5.6098
X10.4008Y5.5993
X10.3998Y5.5882
X10.3995Y5.5740
X10.3997Y5.5661
X10.4004Y5.5552
X10.4018Y5.5443
X10.4035Y5.5339
X10.4059Y5.5231
X10.4087Y5.5131
X10.4120Y5.5030
X10.4159Y5.4930
X10.4202Y5.4835
X10.4246Y5.4744
X10.4300Y5.4650
X10.4356Y5.4563
X10.4413Y5.4480
X10.4479Y5.4396
X10.4545Y5.4318
X10.4616Y5.4242
X10.4689Y5.4172
X10.4765Y5.4104
X10.4849Y5.4038
X10.4934Y5.3977
X10.5018Y5.3922
X10.5108Y5.3869
X10.5202Y5.3820
X10.5296Y5.3777
X10.5396Y5.3737
X10.5493Y5.3703
X10.5597Y5.3672
X10.5702Y5.3648
X10.5805Y5.3628
X10.5917Y5.3614
X10.6024Y5.3605
X10.6165Y5.3601
X10.6244Y5.3603
X10.6354Y5.3611
X10.6459Y5.3623
X10.6570Y5.3642
X10.6672Y5.3665
X10.6775Y5.3693
X10.6878Y5.3728
X10.6973Y5.3764
X10.7071Y5.3807
X10.7164Y5.3854
X10.7256Y5.3906
X10.7343Y5.3962
X10.7426Y5.4019
X10.7509Y5.4084
X10.7589Y5.4153
X10.7661Y5.4220
X10.7734Y5.4295
X10.7803Y5.4374
X10.7867Y5.4454
X10.7929Y5.4541
X10.7984Y5.4624
X10.8037Y5.4715
X10.8087Y5.4811
X10.8129Y5.4902
X10.8168Y5.4999
X10.8203Y5.5102
X10.8233Y5.5204
X10.8257Y5.5305
X10.8278Y5.5414
X10.8292Y5.5520
X10.8301Y5.5630
X10.8305Y5.5772
X10.8303Y5.5850
X10.8295Y5.5960
X10.8282Y5.6069
X10.8264Y5.6174
X10.8240Y5.6281
X10.8213Y5.6380
X10.8179Y5.6483
X10.8141Y5.6581
X10.8098Y5.6678
X10.8053Y5.6768
X10.7999Y5.6863
X10.7945Y5.6948
X10.7887Y5.7032
X10.7820Y5.7118
X10.7755Y5.7194
X10.7683Y5.7270
X10.7610Y5.7341
X10.7532Y5.7409
G0Z-0.0502
Z0.3940
X10.6063Y7.2532
G1Z-0.0500F8.0
X10.5986Y7.2535F20.0
X10.5903Y7.2540
X10.5738Y7.2557
X10.5580Y7.2581
X10.5423Y7.2613
X10.5267Y7.2653
X10.5114Y7.2701
X10.4966Y7.2756
X10.4825Y7.2815
X10.4681Y7.2884
X10.4543Y7.2959
X10.4415Y7.3037
X10.4283Y7.3126
X10.4159Y7.3219
X10.4041Y7.3316
X10.3928Y7.3419
X10.3813Y7.3534
X10.3710Y7.3647
X10.3613Y7.3765
X10.3520Y7.3889
X10.3431Y7.4020
X10.3353Y7.4149
X10.3276Y7.4292
X10.3209Y7.4429
X10.3149Y7.4572
X10.3096Y7.4716
X10.3046Y7.4876
X10.3008Y7.5024
X10.2974Y7.5189
X10.2951Y7.5344
X10.2935Y7.5502
X10.2929Y7.5580
X10.2924Y7.5756
X10.2929Y7.5925
X10.2934Y7.6007
X10.2951Y7.6168
X10.2974Y7.6323
X10.3007Y7.6484
X10.3047Y7.6639
X10.3094Y7.6790
X10.3149Y7.6940
X10.3209Y7.7083
X10.3273Y7.7215
X10.3351Y7.7360
X10.3428Y7.7487
X10.3520Y7.7623
X10.3612Y7.7746
X10.3709Y7.7864
X10.3813Y7.7978
X10.3928Y7.8093
X10.4041Y7.8196
X10.4159Y7.8293
X10.4283Y7.8386
X10.4415Y7.8475
X10.4543Y7.8553
X10.4681Y7.8628
X10.4825Y7.8698
X10.4966Y7.8757
X10.5113Y7.8811
X10.5277Y7.8861
X10.5339Y7.8878
X10.5420Y7.8898
X10.5580Y7.8931
X10.5738Y7.8955
X10.5903Y7.8972
X10.5986Y7.8977
X10.6062Y7.8980
X10.6238
X10.6313Y7.8977
X10.6396Y7.8972
X10.6561Y7.8955
X10.6719Y7.8931
X10.6880Y7.8898
X10.6961Y7.8878
X10.7023Y7.8861
X10.7186Y7.8811
X10.7333Y7.8757
X10.7474Y7.8698
X10.7618Y7.8628
X10.7757Y7.8553
X10.7883Y7.8476
X10.8017Y7.8386
X10.8143Y7.8292
X10.8258Y7.8196
X10.8372Y7.8093
X10.8487Y7.7978
X10.8591Y7.7864
X10.8687Y7.7746
X10.8780Y7.7623
X10.8871Y7.7487
X10.8948Y7.7360
X10.9022Y7.7224
X10.9091Y7.7081
X10.9150Y7.6940
X10.9206Y7.6789
X10.9252Y7.6641
X10.9293Y7.6483
X10.9325Y7.6325
X10.9349Y7.6168
X10.9366Y7.6003
X10.9371Y7.5914
X10.9374Y7.5844
Y7.5667
X10.9371Y7.5598
X10.9365Y7.5502
X10.9349Y7.5344
X10.9325Y7.5187
X10.9292Y7.5028
X10.9253Y7.4873
X10.9204Y7.4716
X10.9150Y7.4572
X10.9091Y7.4431
X10.9022Y7.4288
X10.8946Y7.4149
X10.8868Y7.4020
X10.8780Y7.3889
X10.8687Y7.3765
X10.8589Y7.3647
X10.8487Y7.3534
X10.8372Y7.3419
X10.8258Y7.3316
X10.8143Y7.3220
X10.8017Y7.3126
X10.7883Y7.3036
X10.7757Y7.2959
X10.7618Y7.2884
X10.7474Y7.2815
X10.7333Y7.2756
X10.7185Y7.2701
X10.7033Y7.2653
X10.6877Y7.2613
X10.6719Y7.2581
X10.6561Y7.2557
X10.6396Y7.2540
X10.6313Y7.2535
X10.6237Y7.2532
X10.6150Y7.2531
X10.6063Y7.2532
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.5903Y7.2540
X10.5738Y7.2557
X10.5580Y7.2581
X10.5423Y7.2613
X10.5267Y7.2653
X10.5114Y7.2701
X10.4966Y7.2756
X10.4825Y7.2815
X10.4681Y7.2884
X10.4543Y7.2959
X10.4415Y7.3037
X10.4283Y7.3126
X10.4159Y7.3219
X10.4041Y7.3316
X10.3928Y7.3419
X10.3813Y7.3534
X10.3710Y7.3647
X10.3613Y7.3765
X10.3520Y7.3889
X10.3431Y7.4020
X10.3353Y7.4149
X10.3276Y7.4292
X10.3209Y7.4429
X10.3149Y7.4572
X10.3096Y7.4716
X10.3046Y7.4876
X10.3008Y7.5024
X10.2974Y7.5189
X10.2951Y7.5344
X10.2935Y7.5502
X10.2929Y7.5580
X10.2924Y7.5756
X10.2929Y7.5925
X10.2934Y7.6007
X10.2951Y7.6168
X10.2974Y7.6323
X10.3007Y7.6484
X10.3047Y7.6639
X10.3094Y7.6790
X10.3149Y7.6940
X10.3209Y7.7083
X10.3273Y7.7215
X10.3351Y7.7360
X10.3428Y7.7487
X10.3520Y7.7623
X10.3612Y7.7746
X10.3709Y7.7864
X10.3813Y7.7978
X10.3928Y7.8093
X10.4041Y7.8196
X10.4159Y7.8293
X10.4283Y7.8386
X10.4415Y7.8475
X10.4543Y7.8553
X10.4681Y7.8628
X10.4825Y7.8698
X10.4966Y7.8757
X10.5113Y7.8811
X10.5277Y7.8861
X10.5339Y7.8878
X10.5420Y7.8898
X10.5580Y7.8931
X10.5738Y7.8955
X10.5903Y7.8972
X10.5986Y7.8977
X10.6062Y7.8980
X10.6238
X10.6313Y7.8977
X10.6396Y7.8972
X10.6561Y7.8955
X10.6719Y7.8931
X10.6880Y7.8898
X10.6961Y7.8878
X10.7023Y7.8861
X10.7186Y7.8811
X10.7333Y7.8757
X10.7474Y7.8698
X10.7618Y7.8628
X10.7757Y7.8553
X10.7883Y7.8476
X10.8017Y7.8386
X10.8143Y7.8292
X10.8258Y7.8196
X10.8372Y7.8093
X10.8487Y7.7978
X10.8591Y7.7864
X10.8687Y7.7746
X10.8780Y7.7623
X10.8871Y7.7487
X10.8948Y7.7360
X10.9022Y7.7224
X10.9091Y7.7081
X10.9150Y7.6940
X10.9206Y7.6789
X10.9252Y7.6641
X10.9293Y7.6483
X10.9325Y7.6325
X10.9349Y7.6168
X10.9366Y7.6003
X10.9371Y7.5914
X10.9374Y7.5844
Y7.5667
X10.9371Y7.5598
X10.9365Y7.5502
X10.9349Y7.5344
X10.9325Y7.5187
X10.9292Y7.5028
X10.9253Y7.4873
X10.9204Y7.4716
X10.9150Y7.4572
X10.9091Y7.4431
X10.9022Y7.4288
X10.8946Y7.4149
X10.8868Y7.4020
X10.8780Y7.3889
X10.8687Y7.3765
X10.8589Y7.3647
X10.8487Y7.3534
X10.8372Y7.3419
X10.8258Y7.3316
X10.8143Y7.3220
X10.8017Y7.3126
X10.7883Y7.3036
X10.7757Y7.2959
X10.7618Y7.2884
X10.7474Y7.2815
X10.7333Y7.2756
X10.7185Y7.2701
X10.7033Y7.2653
X10.6877Y7.2613
X10.6719Y7.2581
X10.6561Y7.2557
X10.6396Y7.2540
X10.6313Y7.2535
X10.6237Y7.2532
X10.6150Y7.2531
X10.6063Y7.2532
G0Z-0.0502
Z0.3940
X10.4497Y7.7138
G1Z-0.0500F8.0
X10.4434Y7.7061F20.0
X10.4370Y7.6972
X10.4316Y7.6888
X10.4263Y7.6798
X10.4213Y7.6702
X10.4171Y7.6610
X10.4132Y7.6513
X10.4096Y7.6411
X10.4067Y7.6309
X10.4042Y7.6207
X10.4022Y7.6098
X10.4008Y7.5993
X10.3998Y7.5882
X10.3995Y7.5740
X10.3997Y7.5661
X10.4004Y7.5552
X10.4018Y7.5443
X10.4035Y7.5339
X10.4059Y7.5231
X10.4087Y7.5131
X10.4120Y7.5030
X10.4159Y7.4930
X10.4202Y7.4835
X10.4246Y7.4744
X10.4300Y7.4650
X10.4356Y7.4563
X10.4413Y7.4480
X10.4479Y7.4396
X10.4545Y7.4318
X10.4616Y7.4242
X10.4689Y7.4172
X10.4767Y7.4103
X10.4847Y7.4039
X10.4934Y7.3977
X10.5018Y7.3922
X10.5108Y7.3869
X10.5202Y7.3820
X10.5299Y7.3776
X10.5393Y7.3738
X10.5495Y7.3703
X10.5597Y7.3673
X10.5699Y7.3648
X10.5808Y7.3628
X10.5913Y7.3614
X10.6024Y7.3605
X10.6165Y7.3601
X10.6244Y7.3603
X10.6354Y7.3611
X10.6463Y7.3624
X10.6567Y7.3642
X10.6675Y7.3666
X10.6775Y7.3693
X10.6876Y7.3727
X10.6976Y7.3766
X10.7069Y7.3806
X10.7164Y7.3854
X10.7256Y7.3906
X10.7343Y7.3962
X10.7426Y7.4019
X10.7512Y7.4086
X10.7587Y7.4151
X10.7661Y7.4220
X10.7734Y7.4295
X10.7803Y7.4374
X10.7867Y7.4454
X10.7929Y7.4541
X10.7984Y7.4624
X10.8037Y7.4715
X10.8087Y7.4811
X10.8129Y7.4902
X10.8168Y7.4999
X10.8203Y7.5102
X10.8233Y7.5204
X10.8257Y7.5305
X10.8278Y7.5414
X10.8292Y7.5520
X10.8301Y7.5630
X10.8305Y7.5772
X10.8303Y7.5850
X10.8295Y7.5960
X10.8282Y7.6069
X10.8264Y7.6174
X10.8240Y7.6281
X10.8213Y7.6381
X10.8179Y7.6482
X10.8140Y7.6583
X10.8098Y7.6678
X10.8053Y7.6768
X10.8000Y7.6862
X10.7944Y7.6950
X10.7887Y7.7032
X10.7820Y7.7118
X10.7755Y7.7194
X10.7683Y7.7270
X10.7610Y7.7341
X10.7532Y7.7409
X10.7454Y7.7472
X10.7365Y7.7535
X10.7281Y7.7590
X10.7191Y7.7643
X10.7095Y7.7693
X10.7004Y7.7735
X10.6907Y7.7774
X10.6804Y7.7809
X10.6702Y7.7839
X10.6601Y7.7864
X10.6492Y7.7884
X10.6386Y7.7898
X10.6276Y7.7907
X10.6134Y7.7911
X10.6056Y7.7909
X10.5946Y7.7902
X10.5837Y7.7888
X10.5732Y7.7870
X10.5625Y7.7846
X10.5525Y7.7819
X10.5424Y7.7785
X10.5323Y7.7746
X10.5228Y7.7704
X10.5138Y7.7659
X10.5044Y7.7606
X10.4956Y7.7550
X10.4874Y7.7493
X10.4789Y7.7427
X10.4712Y7.7361
X10.4635Y7.7288
X10.4565Y7.7217
X10.4497Y7.7138
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.4370Y7.6972
X10.4316Y7.6888
X10.4263Y7.6798
X10.4213Y7.6702
X10.4171Y7.6610
X10.4132Y7.6513
X10.4096Y7.6411
X10.4067Y7.6309
X10.4042Y7.6207
X10.4022Y7.6098
X10.4008Y7.5993
X10.3998Y7.5882
X10.3995Y7.5740
X10.3997Y7.5661
X10.4004Y7.5552
X10.4018Y7.5443
X10.4035Y7.5339
X10.4059Y7.5231
X10.4087Y7.5131
X10.4120Y7.5030
X10.4159Y7.4930
X10.4202Y7.4835
X10.4246Y7.4744
X10.4300Y7.4650
X10.4356Y7.4563
X10.4413Y7.4480
X10.4479Y7.4396
X10.4545Y7.4318
X10.4616Y7.4242
X10.4689Y7.4172
X10.4767Y7.4103
X10.4847Y7.4039
X10.4934Y7.3977
X10.5018Y7.3922
X10.5108Y7.3869
X10.5202Y7.3820
X10.5299Y7.3776
X10.5393Y7.3738
X10.5495Y7.3703
X10.5597Y7.3673
X10.5699Y7.3648
X10.5808Y7.3628
X10.5913Y7.3614
X10.6024Y7.3605
X10.6165Y7.3601
X10.6244Y7.3603
X10.6354Y7.3611
X10.6463Y7.3624
X10.6567Y7.3642
X10.6675Y7.3666
X10.6775Y7.3693
X10.6876Y7.3727
X10.6976Y7.3766
X10.7069Y7.3806
X10.7164Y7.3854
X10.7256Y7.3906
X10.7343Y7.3962
X10.7426Y7.4019
X10.7512Y7.4086
X10.7587Y7.4151
X10.7661Y7.4220
X10.7734Y7.4295
X10.7803Y7.4374
X10.7867Y7.4454
X10.7929Y7.4541
X10.7984Y7.4624
X10.8037Y7.4715
X10.8087Y7.4811
X10.8129Y7.4902
X10.8168Y7.4999
X10.8203Y7.5102
X10.8233Y7.5204
X10.8257Y7.5305
X10.8278Y7.5414
X10.8292Y7.5520
X10.8301Y7.5630
X10.8305Y7.5772
X10.8303Y7.5850
X10.8295Y7.5960
X10.8282Y7.6069
X10.8264Y7.6174
X10.8240Y7.6281
X10.8213Y7.6381
X10.8179Y7.6482
X10.8140Y7.6583
X10.8098Y7.6678
X10.8053Y7.6768
X10.8000Y7.6862
X10.7944Y7.6950
X10.7887Y7.7032
X10.7820Y7.7118
X10.7755Y7.7194
X10.7683Y7.7270
X10.7610Y7.7341
X10.7532Y7.7409
X10.7454Y7.7472
X10.7365Y7.7535
X10.7281Y7.7590
X10.7191Y7.7643
X10.7095Y7.7693
X10.7004Y7.7735
X10.6907Y7.7774
X10.6804Y7.7809
X10.6702Y7.7839
X10.6601Y7.7864
X10.6492Y7.7884
X10.6386Y7.7898
X10.6276Y7.7907
X10.6134Y7.7911
X10.6056Y7.7909
X10.5946Y7.7902
X10.5837Y7.7888
X10.5732Y7.7870
X10.5625Y7.7846
X10.5525Y7.7819
X10.5424Y7.7785
X10.5323Y7.7746
X10.5228Y7.7704
X10.5138Y7.7659
X10.5044Y7.7606
X10.4956Y7.7550
X10.4874Y7.7493
X10.4789Y7.7427
X10.4712Y7.7361
X10.4635Y7.7288
X10.4565Y7.7217
X10.4497Y7.7138
G0Z-0.0502
Z0.3940
X10.6063Y9.2532
G1Z-0.0500F8.0
X10.5986Y9.2535F20.0
X10.5903Y9.2540
X10.5738Y9.2557
X10.5580Y9.2581
X10.5423Y9.2613
X10.5267Y9.2653
X10.5114Y9.2701
X10.4966Y9.2756
X10.4825Y9.2815
X10.4681Y9.2884
X10.4543Y9.2959
X10.4415Y9.3037
X10.4283Y9.3126
X10.4159Y9.3219
X10.4041Y9.3316
X10.3928Y9.3419
X10.3813Y9.3534
X10.3710Y9.3647
X10.3614Y9.3763
X10.3520Y9.3889
X10.3430Y9.4023
X10.3353Y9.4149
X10.3276Y9.4292
X10.3209Y9.4429
X10.3149Y9.4572
X10.3096Y9.4716
X10.3047Y9.4874
X10.3009Y9.5021
X10.2974Y9.5189
X10.2951Y9.5344
X10.2935Y9.5502
X10.2929Y9.5580
X10.2924Y9.5756
X10.2929Y9.5925
X10.2934Y9.6007
X10.2951Y9.6168
X10.2974Y9.6323
X10.3007Y9.6483
X10.3047Y9.6639
X10.3094Y9.6790
X10.3149Y9.6940
X10.3209Y9.7083
X10.3273Y9.7215
X10.3351Y9.7360
X10.3428Y9.7487
X10.3520Y9.7623
X10.3613Y9.7747
X10.3710Y9.7865
X10.3813Y9.7978
X10.3928Y9.8093
X10.4039Y9.8194
X10.4159Y9.8293
X10.4285Y9.8387
X10.4415Y9.8475
X10.4546Y9.8555
X10.4680Y9.8627
X10.4760Y9.8667
X10.4817Y9.8694
X10.4900Y9.8730
X10.4961Y9.8755
X10.5113Y9.8811
X10.5269Y9.8859
X10.5422Y9.8898
X10.5580Y9.8931
X10.5738Y9.8955
X10.5903Y9.8972
X10.5986Y9.8977
X10.6062Y9.8980
X10.6238
X10.6313Y9.8977
X10.6396Y9.8972
X10.6561Y9.8955
X10.6719Y9.8931
X10.6878Y9.8898
X10.7030Y9.8859
X10.7186Y9.8811
X10.7338Y9.8755
X10.7400Y9.8730
X10.7482Y9.8694
X10.7539Y9.8667
X10.7620Y9.8627
X10.7754Y9.8555
X10.7883Y9.8476
X10.8019Y9.8384
X10.8138Y9.8295
X10.8260Y9.8194
X10.8372Y9.8093
X10.8487Y9.7978
X10.8590Y9.7865
X10.8687Y9.7747
X10.8780Y9.7623
X10.8871Y9.7487
X10.8948Y9.7360
X10.9022Y9.7224
X10.9091Y9.7081
X10.9150Y9.6940
X10.9206Y9.6789
X10.9252Y9.6641
X10.9293Y9.6483
X10.9325Y9.6325
X10.9349Y9.6168
X10.9366Y9.6003
X10.9371Y9.5914
X10.9374Y9.5844
Y9.5667
X10.9371Y9.5598
X10.9365Y9.5502
X10.9349Y9.5344
X10.9325Y9.5187
X10.9292Y9.5028
X10.9252Y9.4872
X10.9204Y9.4716
X10.9150Y9.4572
X10.9091Y9.4431
X10.9022Y9.4288
X10.8946Y9.4149
X10.8870Y9.4023
X10.8780Y9.3889
X10.8685Y9.3763
X10.8589Y9.3647
X10.8487Y9.3534
X10.8372Y9.3419
X10.8258Y9.3316
X10.8143Y9.3220
X10.8017Y9.3126
X10.7883Y9.3036
X10.7757Y9.2959
X10.7618Y9.2884
X10.7474Y9.2815
X10.7333Y9.2756
X10.7185Y9.2701
X10.7033Y9.2653
X10.6877Y9.2613
X10.6719Y9.2581
X10.6561Y9.2557
X10.6396Y9.2540
X10.6313Y9.2535
X10.6237Y9.2532
X10.6150Y9.2531
X10.6063Y9.2532
G0Z-0.0402
Z-0.0002
G1Z-0.0600F8.0
X10.5903Y9.2540
X10.5738Y9.2557
X10.5580Y9.2581
X10.5423Y9.2613
X10.5267Y9.2653
X10.5114Y9.2701
X10.4966Y9.2756
X10.4825Y9.2815
X10.4681Y9.2884
X10.4543Y9.2959
X10.4415Y9.3037
X10.4283Y9.3126
X10.4159Y9.3219
X10.4041Y9.3316
X10.3928Y9.3419
X10.3813Y9.3534
X10.3710Y9.3647
X10.3614Y9.3763
X10.3520Y9.3889
X10.3430Y9.4023
X10.3353Y9.4149
X10.3276Y9.4292
X10.3209Y9.4429
X10.3149Y9.4572
X10.3096Y9.4716
X10.3047Y9.4874
X10.3009Y9.5021
X10.2974Y9.5189
X10.2951Y9.5344
X10.2935Y9.5502
X10.2929Y9.5580
X10.2924Y9.5756
X10.2929Y9.5925
X10.2934Y9.6007
X10.2951Y9.6168
X10.2974Y9.6323
X10.3007Y9.6483
X10.3047Y9.6639
X10.3094Y9.6790
X10.3149Y9.6940
X10.3209Y9.7083
X10.3273Y9.7215
X10.3351Y9.7360
X10.3428Y9.7487
X10.3520Y9.7623
X10.3613Y9.7747
X10.3710Y9.7865
X10.3813Y9.7978
X10.3928Y9.8093
X10.4039Y9.8194
X10.4159Y9.8293
X10.4285Y9.8387
X10.4415Y9.8475
X10.4546Y9.8555
X10.4680Y9.8627
X10.4760Y9.8667
X10.4817Y9.8694
X10.4900Y9.8730
X10.4961Y9.8755
X10.5113Y9.8811
X10.5269Y9.8859
X10.5422Y9.8898
X10.5580Y9.8931
X10.5738Y9.8955
X10.5903Y9.8972
X10.5986Y9.8977
X10.6062Y9.8980
X10.6238
X10.6313Y9.8977
X10.6396Y9.8972
X10.6561Y9.8955
X10.6719Y9.8931
X10.6878Y9.8898
X10.7030Y9.8859
X10.7186Y9.8811
X10.7338Y9.8755
X10.7400Y9.8730
X10.7482Y9.8694
X10.7539Y9.8667
X10.7620Y9.8627
X10.7754Y9.8555
X10.7883Y9.8476
X10.8019Y9.8384
X10.8138Y9.8295
X10.8260Y9.8194
X10.8372Y9.8093
X10.8487Y9.7978
X10.8590Y9.7865
X10.8687Y9.7747
X10.8780Y9.7623
X10.8871Y9.7487
X10.8948Y9.7360
X10.9022Y9.7224
X10.9091Y9.7081
X10.9150Y9.6940
X2.6313Y9.8977
X2.6396Y9.8972
X2.6561Y9.8955
X2.6719Y9.8931
X2.6878Y9.8898
X2.7030Y9.8859
X2.7186Y9.8811
X2.7338Y9.8755
G0Z-0.0502
Z0.3940
M05
M02
spinorose
(Spinorose)
September 18, 2024, 11:06pm
15
Does Marlin have a different way of reading the Gcode from the converted carbide create gcode ?
vicious1
(Ryan)
September 22, 2024, 12:17am
17
There is not enough detail here for us to know what you did or what is not working for you.
I highly suggest you start your own new topic, this is an old topic from someone else started a long time ago. This is your second different issue from the original post. We try to help a lot of people, so when a thread gets confusing like this it makes it harder on us.
vicious1
(Ryan)
Closed
March 3, 2026, 9:09pm
19
