0-10V Spindle Controller and dial pendant on jackpot possible?
@jeyeager alle the errors occured on different attemps.
I’m not refreshing the UI, and the UI is open only on one device. I just started the job and let it run without any interference.
I got a few examples:
  1. I started the jackpot, connected to wifi, the WebUI popped up, but before I could interact, the starting procedere stopped, lost connection and I coppied this from starting procedere:
$SS
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
[MSG:INFO: FluidNC v3.9.1 https://github.com/bdring/FluidNC]
[MSG:INFO: Machine LowRider]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (0.000,800.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110]
[MSG:INFO:  X Neg Limit gpio.25]
[MSG:INFO: Axis Y (0.000,1600.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110]
[MSG:INFO:  Y Neg Limit gpio.33]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110]
[MSG:INFO:  Y2 Neg Limit gpio.35]
[MSG:INFO: Axis Z (0.000,100.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110]
[MSG:INFO:  Z Pos Limit gpio.32]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110]
[MSG:INFO:  Z2 Pos Limit gpio.34]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low]
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
Grbl 3.9 [FluidNC v3.9.1 (wifi) '$' for help]
$Report/Interval=300
[MSG:INFO: websocket auto report interval set to 300 ms]
ok
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,90>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,80>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,60>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,30>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,10>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:101,100,10>
[MSG:ERR: Channel device rejected config]
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:102,100,10>
  1. I restarted the jackpot, everting seemed ok, I typed $SS and got this:
ok
$SS
[MSG:INFO:   Motor0]
[MSG:INFO:   Motor0]
[MSG:INFO:   Motor1]
[MSG:INFO:   Motor0]
[MSG:INFO:   Motor1]
[MSG:INFO: WiFi on]
ok
  1. Then I just homed and jogged the machine, it stopped and the gantry fell down, the ALARM3 message showed up, the wifi showed still connected, this is what showed in the feed, I shortened it, it kept going on:
<Jog|MPos:0.000,155.780,100.000|FS:3000,0|Ov:100,100,100>
$J=G91 G21 F500 Z-10
ok
<Jog|MPos:0.000,300.000,99.925|FS:500,0>
[MSG:INFO: ALARM: Abort Cycle]
ALARM:3
Reset while in motion. Machine position is likely lost due to sudden halt. Re-homing is highly recommended.
ok
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|WCO:0.000,0.000,0.000>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:100,100,100>
ok
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:100,5,100>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:101,5,100>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:103,5,100>
ok
ok
ok
ok
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:135,100,81>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:139,100,71>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:136,100,90>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:142,100,21>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:135,100,80>
[MSG:INFO: Check door]
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:148,100,100>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:158,100,90>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:104,100,10>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:104,5,50>
ok
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:133,100,10>
<Alarm|MPos:0.000,300.000,90.000|FS:0,0|Ov:100,100,90>
and after I restarted, jogged around, executed 3 files with no spindle, all stable. the only thing I changed, I turned the fan from the jackpotcase off…
OK that is really interesting.
Can you provide details about the fan and how you have it connected? Model, rated voltage, where and how you have it wired in?
Can you post a picture of the fan and wiring for it?
thanks for all the support!!!
the fan is this one: SUNON 24V DC 0,65W 50x50x15mm 22,1m³/h 5000U/Min 22,1m³/h Sunon MF50152V21000UA99, https://www.amazon.de/dp/B07G12V64L?ref=ppx_yo2ov_dt_b_fed_asin_title
the fan is connected to the power of the board.
during the successfull run the fan was always on, just the lid was off the case.
the next thing I will check is to make sure, that the fan-cables don’t cross the antenna… I’ll keep you updated.
Some advice based on the picture, regarding best practices.
You really want connections to your controller electronics to be high reliability, and what I think I see are multiple stranded wires landed in the Jackpot VMOT screw terminals,
That’s a bad practice. It can allow intermittent connections, and the smaller wire will more likely have intermittent connection than the larger. It’s also the case that the screw compression terminal block will allow the birdcaged wires to compress and relax. It’s a recipe for intermittent connections.
What are better options:
  • Use a compression ferrule that can receive both the power and fan wires. The compression ferrule will not relax, and will not allow the wire to come out. Benefit- no intermittent connection and less chance for the Jackpot screw terminal to loosen.
  • Instead of a compression ferrule, use terminal blocks outside of the jackpot for power distribution. I prefer either lever locking or spring lever terminal blocks as they maintain compression of the wire to terminal block without needing tightening.
  • If you’re good at soldering you can solder up a pigtail that Ys out power with one set going to jackpot and one to your fan.
What you want to avoid at all costs is for any of the wiring on your controller to be able to have an intermittent connection.
Below is an example of the cheap compression ferrule kit that I have.
it has a crimp tool that has four jaws that ratchet in to firmly compress the wire.
thanks for the hint!! I will look into it.
