Z probe started going up at start of job?
Hello all,
Hoping another set of eyes can help here as I don’t know were to go with this. My LR4 has started going up all of a sudden on the Z probe at the start of a job. I have run this same job and others just a few days ago and it worked fine. If a do a z probe with the command ‘G38.2 Z-100 F60’ it works fine, going the direction expected, and stopping on contact with touch plate.
The only thing that has changed was that I noticed I was loosing steps on one of the Z axis steppers in the last job I ran. This means the beam was falling out of level during the job. This is a sign that I need to clean the linear rails that the Z axis goes up and down on. I don’t have working dust collection right now and it slowly fouls these rails. Once this was done I did the z level processes as talked about here. I tweaked the Z motor 1 to make some adjustments, as there was a couple MM out of plain.
I then, thinking all was sorted, went and ran my job again. Much to my surprise the Z axis went up and ground against the top of the travel and then stopped. I have done the reset in the web gui, restarted the controller. Re-homed the machine. Nothing I can think of has impacted this. That doesn’t mean much as I am not sure where to go with this. What am I missing here? What might have changed as this was working days?
I am running the FluidCNC controller from V1. Shipped with the firmware and I haven’t re -flashed it or anything like that. Here is the $SS output.
$ss output
$SS
MSG:INFO: FluidNC v3.9.1 https://github.com/bdring/FluidNC
MSG:INFO: Compiled with ESP32 SDK:v4.4.7-dirty
MSG:INFO: Local filesystem type is littlefs
MSG:INFO: Configuration file:config.yaml
MSG:INFO: Machine LowRider
MSG:INFO: Board Jackpot TMC2209
MSG:INFO: UART1 Tx:gpio.0 Rx:gpio.4 RTS:NO_PIN Baud:115200
MSG:INFO: UART2 Tx:gpio.14 Rx:gpio.13 RTS:NO_PIN Baud:1000000
MSG:INFO: uart_channel2 created at report interval: 75
MSG:INFO: I2SO BCK:gpio.22 WS:gpio.17 DATA:gpio.21
MSG:INFO: SPI SCK:gpio.18 MOSI:gpio.23 MISO:gpio.19
MSG:INFO: SD Card cs_pin:gpio.5 detect:NO_PIN freq:20000000
MSG:INFO: Stepping:I2S_STATIC Pulse:2us Dsbl Delay:0us Dir Delay:1us Idle Delay:255ms
MSG:INFO: User Digital Output: 0 on Pin:gpio.26
MSG:INFO: User Digital Output: 1 on Pin:gpio.27
MSG:INFO: Axis count 3
MSG:INFO: Axis X (3.000,1263.000)
MSG:INFO: Motor0
MSG:INFO: tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110
MSG:INFO: X Neg Limit gpio.25
MSG:INFO: Axis Y (3.000,2483.000)
MSG:INFO: Motor0
MSG:INFO: tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110
MSG:INFO: Y Neg Limit gpio.33
MSG:INFO: Motor1
MSG:INFO: tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110
MSG:INFO: Y2 Neg Limit gpio.35
MSG:INFO: Axis Z (-297.000,3.000)
MSG:INFO: Motor0
MSG:INFO: tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110
MSG:INFO: Z Pos Limit gpio.32
MSG:INFO: Motor1
MSG:INFO: tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110
MSG:INFO: Z2 Pos Limit gpio.34
MSG:INFO: X Axis driver test passed
MSG:INFO: Y Axis driver test passed
MSG:INFO: Y2 Axis driver test passed
MSG:INFO: Z Axis driver test passed
MSG:INFO: Z2 Axis driver test passed
MSG:INFO: Kinematic system: Cartesian
MSG:INFO: STA SSID is not set
MSG:INFO: AP SSID FluidNC IP 192.168.0.1 mask 255.255.255.0 channel 1
MSG:INFO: AP started
MSG:INFO: WiFi on
MSG:INFO: Captive Portal Started
MSG:INFO: HTTP started on port 80
MSG:INFO: Telnet started on port 23
MSG:INFO: Flood coolant gpio.2
MSG:INFO: Mist coolant gpio.16
MSG:INFO: Probe gpio.36:low
ok
Here is my config.yaml, if this helps. The only item I think I changed was the Z Motor 0 pulloff_mm
config.yaml
board: Jackpot TMC2209
meta: 10-31-2024 RyanZ
stepping:
engine: I2S_STATIC
idle_ms: 255
pulse_us: 2
dir_delay_us: 1
disable_delay_us: 0
segments: 12
uart1:
txd_pin: gpio.0
rxd_pin: gpio.4
rts_pin: NO_PIN
cts_pin: NO_PIN
baud: 115200
mode: 8N1
uart2:
txd_pin: gpio.14
rxd_pin: gpio.13
rts_pin: NO_PIN
cts_pin: NO_PIN
baud: 1000000
mode: 8N1
uart_channel2:
report_interval_ms: 75
uart_num: 2
message_level: Verbose
i2so:
bck_pin: gpio.22
data_pin: gpio.21
ws_pin: gpio.17
spi:
miso_pin: gpio.19
mosi_pin: gpio.23
sck_pin: gpio.18
sdcard:
cs_pin: gpio.5
card_detect_pin: NO_PIN
frequency_hz: 20000000
kinematics:
Cartesian:
axes:
shared_stepper_disable_pin: NO_PIN
shared_stepper_reset_pin: NO_PIN
homing_runs: 2
x:
steps_per_mm: 50.000000
max_rate_mm_per_min: 9000.000000
acceleration_mm_per_sec2: 200.000000
max_travel_mm: 1260.000000
soft_limits: false
homing:
cycle: 2
allow_single_axis: true
positive_direction: false
mpos_mm: 3.000000
feed_mm_per_min: 300.000000
seek_mm_per_min: 1500.000000
settle_ms: 500
seek_scaler: 1.100000
feed_scaler: 1.100000
motor0:
  limit_neg_pin: gpio.25
  limit_pos_pin: NO_PIN
  limit_all_pin: NO_PIN
  hard_limits: false
  pulloff_mm: 4.000000
  tmc_2209:
    addr: 0
    cs_pin: NO_PIN
    uart_num: 1
    step_pin: I2SO.2
    direction_pin: I2SO.1
    disable_pin: I2SO.0
    r_sense_ohms: 0.110000
    run_amps: 0.800000
    hold_amps: 0.700000
    microsteps: 8
    toff_disable: 0
    toff_stealthchop: 5
    use_enable: false
    run_mode: StealthChop
    homing_mode: StealthChop
    homing_amps: 0.800000
    stallguard: 0
    stallguard_debug: false
    toff_coolstep: 3
y:
max_travel_mm: 2480.000000
soft_limits: false
homing:
cycle: 2
mpos_mm: 3.000000
settle_ms: 500
motor0:
  limit_neg_pin: gpio.33
  hard_limits: false
  tmc_2209:
    addr: 1
    cs_pin: NO_PIN
    uart_num: 1
    step_pin: I2SO.5
    direction_pin: I2SO.4
    disable_pin: I2SO.7
    run_amps: 0.800000
    hold_amps: 0.700000
    microsteps: 8
    toff_disable: 0
    toff_stealthchop: 5
    use_enable: false
    stallguard: 0
    toff_coolstep: 3
motor1:
  limit_neg_pin: gpio.35
  hard_limits: false
  tmc_2209:
    addr: 3
    cs_pin: I2SO.14
    uart_num: 1
    step_pin: I2SO.13
    direction_pin: I2SO.12
    disable_pin: I2SO.15
    run_amps: 0.800000
    hold_amps: 0.700000
    microsteps: 8
    toff_disable: 0
    toff_stealthchop: 5
    use_enable: false
    stallguard: 0
    toff_coolstep: 3
z:
steps_per_mm: 200.000000
max_rate_mm_per_min: 1800.000000
acceleration_mm_per_sec2: 80.000000
max_travel_mm: 300.000000
soft_limits: false
homing:
cycle: 1
positive_direction: true
mpos_mm: 3.000000
feed_mm_per_min: 200.000000
seek_mm_per_min: 800.000000
settle_ms: 500
motor0:
  limit_neg_pin: NO_PIN
  limit_pos_pin: gpio.32
  hard_limits: false
  pulloff_mm: 7.000000
  tmc_2209:
    addr: 2
    cs_pin: NO_PIN
    uart_num: 1
    step_pin: I2SO.10
    direction_pin: I2SO.9
    disable_pin: I2SO.8
    run_amps: 0.800000
    hold_amps: 0.700000
    microsteps: 8
    toff_disable: 0
    toff_stealthchop: 5
    use_enable: false
    stallguard: 0
    toff_coolstep: 3
motor1:
  limit_pos_pin: gpio.34
  hard_limits: false
  tmc_2209:
    addr: 3
    cs_pin: I2SO.19
    uart_num: 1
    step_pin: I2SO.18
    direction_pin: I2SO.17
    disable_pin: I2SO.16
    run_amps: 0.800000
    hold_amps: 0.700000
    microsteps: 8
    toff_disable: 0
    toff_stealthchop: 5
    use_enable: false
    stallguard: 0
    toff_coolstep: 3
control:
safety_door_pin: NO_PIN
reset_pin: NO_PIN
feed_hold_pin: NO_PIN
cycle_start_pin: NO_PIN
macro0_pin: NO_PIN
macro1_pin: NO_PIN
macro2_pin: NO_PIN
macro3_pin: NO_PIN
fault_pin: NO_PIN
estop_pin: NO_PIN
coolant:
flood_pin: gpio.2
mist_pin: gpio.16
delay_ms: 0
probe:
pin: ‘gpio.36:low’
toolsetter_pin: NO_PIN
check_mode_start: true
hard_stop: false
macros:
startup_line0:
startup_line1:
Macro0:
Macro1:
Macro2:
Macro3:
after_homing:
after_reset:
after_unlock:
start:
must_home: false
deactivate_parking: false
check_limits: true
parking:
enable: false
axis: Z
target_mpos_mm: -5.000000
rate_mm_per_min: 800.000000
pullout_distance_mm: 5.000000
pullout_rate_mm_per_min: 250.000000
user_outputs:
analog0_pin: NO_PIN
analog1_pin: NO_PIN
analog2_pin: NO_PIN
analog3_pin: NO_PIN
analog0_hz: 5000
analog1_hz: 5000
analog2_hz: 5000
analog3_hz: 5000
digital0_pin: gpio.26
digital1_pin: gpio.27
digital2_pin: NO_PIN
digital3_pin: NO_PIN
digital4_pin: NO_PIN
digital5_pin: NO_PIN
digital6_pin: NO_PIN
digital7_pin: NO_PIN
user_inputs:
analog0_pin: NO_PIN
analog1_pin: NO_PIN
analog2_pin: NO_PIN
analog3_pin: NO_PIN
digital0_pin: NO_PIN
digital1_pin: NO_PIN
arc_tolerance_mm: 0.002000
junction_deviation_mm: 0.010000
verbose_errors: true
report_inches: false
enable_parking_override_control: false
use_line_numbers: false
planner_blocks: 32
*Edit: fixed ss output text.
Share the gcode. If the command by itself works, it could be other gcode commands.
For this, I would lube the lead screws. That has fixed this problem for me. I don’t think I’ve ever done anything with the linear rails.
Here is the code that I am running.
gcode
;Project Boreline_Roller_Rings-100mm RingPad
;Created by Estlcam version 12 build 12.126
;Machining time about 00:03:15 hours
G92 X0 Y0 ; Set Current position to 0 on the X and Y axes.
M0 (Attach probe) ; Pause to connect touchplate
G38.2 Z0 F200; Probe down to touchplate
G92 Z13 ; Set new Z position to thickness of touchplate
G1 Z30.0000 F900 ; Lift off touchplate
M0 (Remove probe) ; Pause and wait for touchplate removal
;M106 ; This will turn on an IOT relay to start a router or vacuum
G00 Z5.0000 F900
;No. 1: Hole 1
G00 X50.0000 Y23.0005 Z5.0000 F2400
G01 Z0.0000 F900 S24000
G01 X49.7800 Y23.0042 Z-0.0158 F900
G01 X49.5601 Y23.0080 Z-0.0628 F900
G01 X49.3401 Y23.0117 Z-0.1404 F900
G01 X49.1202 Y23.0155 Z-0.2474 F900
G01 X49.0835 Y23.0161 Z-0.2679 F900
G01 X48.9004 Y23.0254 Z-0.3820 F900
G01 X48.6807 Y23.0367 Z-0.5421 F900
G01 X48.4610 Y23.0479 Z-0.7252 F900
G01 X48.2413 Y23.0592 Z-0.9283 F900
G01 X48.1680 Y23.0629 Z-1.0000 F900
G01 X48.0219 Y23.0754 Z-1.1484 F900
G01 X47.8027 Y23.0941 Z-1.3820 F900
G01 X47.5835 Y23.1129 Z-1.6252 F900
G01 X47.3643 Y23.1316 Z-1.8744 F900
G01 X47.2547 Y23.1410 Z-2.0000 F900
G01 X47.1455 Y23.1540 Z-2.1256 F900
G01 X46.9271 Y23.1802 Z-2.3748 F900
G01 X46.7086 Y23.2064 Z-2.6180 F900
G01 X46.4902 Y23.2326 Z-2.8516 F900
G01 X46.3446 Y23.2501 Z-3.0000 F900
G01 X46.2721 Y23.2613 Z-3.0717 F900
G01 X46.0547 Y23.2949 Z-3.2748 F900
G01 X45.8373 Y23.3285 Z-3.4579 F900
G01 X45.6199 Y23.3621 Z-3.6180 F900
G01 X45.4387 Y23.3901 Z-3.7321 F900
G01 X45.4027 Y23.3970 Z-3.7526 F900
G01 X45.1865 Y23.4380 Z-3.8596 F900
G01 X44.9704 Y23.4790 Z-3.9372 F900
G01 X44.7543 Y23.5200 Z-3.9842 F900
G01 X44.5381 Y23.5610 Z-4.0000 F900
G01 X44.3865 Y23.5905 F900
G02 Y76.4095 I5.6135 J26.4095 F900
G01 X44.5381 Y76.4390 F900
G01 X44.7543 Y76.4800 Z-3.9842 F900
G01 X44.9704 Y76.5210 Z-3.9372 F900
G01 X45.1865 Y76.5620 Z-3.8596 F900
G01 X45.4027 Y76.6030 Z-3.7526 F900
G01 X45.4387 Y76.6099 Z-3.7321 F900
G01 X45.6199 Y76.6379 Z-3.6180 F900
G01 X45.8373 Y76.6715 Z-3.4579 F900
G01 X46.0547 Y76.7051 Z-3.2748 F900
G01 X46.2721 Y76.7387 Z-3.0717 F900
G01 X46.3446 Y76.7499 Z-3.0000 F900
G01 X46.4902 Y76.7674 Z-2.8516 F900
G01 X46.7086 Y76.7936 Z-2.6180 F900
G01 X46.9271 Y76.8198 Z-2.3748 F900
G01 X47.1455 Y76.8459 Z-2.1256 F900
G01 X47.2547 Y76.8590 Z-2.0000 F900
G01 X47.3643 Y76.8684 Z-1.8744 F900
G01 X47.5835 Y76.8871 Z-1.6252 F900
G01 X47.8027 Y76.9059 Z-1.3820 F900
G01 X48.0219 Y76.9246 Z-1.1484 F900
G01 X48.1680 Y76.9371 Z-1.0000 F900
G01 X48.2413 Y76.9408 Z-0.9283 F900
G01 X48.4610 Y76.9521 Z-0.7252 F900
G01 X48.6807 Y76.9633 Z-0.5421 F900
G01 X48.9004 Y76.9745 Z-0.3820 F900
G01 X49.0835 Y76.9839 Z-0.2679 F900
G01 X49.1202 Y76.9845 Z-0.2474 F900
G01 X49.3401 Y76.9883 Z-0.1404 F900
G01 X49.5601 Y76.9920 Z-0.0628 F900
G01 X49.7800 Y76.9958 Z-0.0158 F900
G01 X50.0000 Y76.9995 Z0.0000 F900
G01 X50.2200 Y76.9958 Z-0.0158 F900
G01 X50.4399 Y76.9920 Z-0.0628 F900
G01 X50.6599 Y76.9883 Z-0.1404 F900
G01 X50.8799 Y76.9845 Z-0.2474 F900
G01 X50.9165 Y76.9839 Z-0.2679 F900
G01 X51.0996 Y76.9745 Z-0.3820 F900
G01 X51.3193 Y76.9633 Z-0.5421 F900
G01 X51.5390 Y76.9521 Z-0.7252 F900
G01 X51.7587 Y76.9408 Z-0.9283 F900
G01 X51.8320 Y76.9371 Z-1.0000 F900
G01 X51.9781 Y76.9246 Z-1.1484 F900
G01 X52.1973 Y76.9059 Z-1.3820 F900
G01 X52.4165 Y76.8871 Z-1.6252 F900
G01 X52.6357 Y76.8684 Z-1.8744 F900
G01 X52.7453 Y76.8590 Z-2.0000 F900
G01 X52.8545 Y76.8459 Z-2.1256 F900
G01 X53.0729 Y76.8198 Z-2.3748 F900
G01 X53.2914 Y76.7936 Z-2.6180 F900
G01 X53.5098 Y76.7674 Z-2.8516 F900
G01 X53.6554 Y76.7499 Z-3.0000 F900
G01 X53.7279 Y76.7387 Z-3.0717 F900
G01 X53.9453 Y76.7051 Z-3.2748 F900
G01 X54.1627 Y76.6715 Z-3.4579 F900
G01 X54.3801 Y76.6379 Z-3.6180 F900
G01 X54.5613 Y76.6099 Z-3.7321 F900
G01 X54.5973 Y76.6030 Z-3.7526 F900
G01 X54.8135 Y76.5620 Z-3.8596 F900
G01 X55.0296 Y76.5210 Z-3.9372 F900
G01 X55.2457 Y76.4800 Z-3.9842 F900
G01 X55.4619 Y76.4390 Z-4.0000 F900
G01 X55.6135 Y76.4095 F900
G02 Y23.5905 I-5.6135 J-26.4095 F900
G01 X55.4619 Y23.5610 F900
G01 X55.2457 Y23.5200 Z-3.9842 F900
G01 X55.0296 Y23.4790 Z-3.9372 F900
G01 X54.8135 Y23.4380 Z-3.8596 F900
G01 X54.5973 Y23.3970 Z-3.7526 F900
G01 X54.5613 Y23.3901 Z-3.7321 F900
G01 X54.3801 Y23.3621 Z-3.6180 F900
G01 X54.1627 Y23.3285 Z-3.4579 F900
G01 X53.9453 Y23.2949 Z-3.2748 F900
G01 X53.7279 Y23.2613 Z-3.0717 F900
G01 X53.6554 Y23.2501 Z-3.0000 F900
G01 X53.5098 Y23.2326 Z-2.8516 F900
G01 X53.2914 Y23.2064 Z-2.6180 F900
G01 X53.0729 Y23.1802 Z-2.3748 F900
G01 X52.8545 Y23.1540 Z-2.1256 F900
G01 X52.7453 Y23.1410 Z-2.0000 F900
G01 X52.6357 Y23.1316 Z-1.8744 F900
G01 X52.4165 Y23.1129 Z-1.6252 F900
G01 X52.1973 Y23.0941 Z-1.3820 F900
G01 X51.9781 Y23.0754 Z-1.1484 F900
G01 X51.8320 Y23.0629 Z-1.0000 F900
G01 X51.7587 Y23.0592 Z-0.9283 F900
G01 X51.5390 Y23.0479 Z-0.7252 F900
G01 X51.3193 Y23.0367 Z-0.5421 F900
G01 X51.0996 Y23.0254 Z-0.3820 F900
G01 X50.9165 Y23.0161 Z-0.2679 F900
G01 X50.8799 Y23.0155 Z-0.2474 F900
G01 X50.6599 Y23.0117 Z-0.1404 F900
G01 X50.4399 Y23.0080 Z-0.0628 F900
G01 X50.2200 Y23.0042 Z-0.0158 F900
G01 X50.0000 Y23.0005 Z0.0000 F900
G01 X49.7800 Y23.0042 Z-0.0315 F900
G01 X49.5601 Y23.0080 Z-0.1257 F900
G01 X49.3401 Y23.0117 Z-0.2809 F900
G01 X49.1202 Y23.0155 Z-0.4948 F900
G01 X49.0835 Y23.0161 Z-0.5359 F900
G01 X48.9004 Y23.0254 Z-0.7639 F900
G01 X48.6807 Y23.0367 Z-1.0841 F900
G01 X48.4610 Y23.0479 Z-1.4503 F900
G01 X48.2413 Y23.0592 Z-1.8567 F900
G01 X48.1680 Y23.0629 Z-2.0000 F900
G01 X48.0219 Y23.0754 Z-2.2969 F900
G01 X47.8027 Y23.0941 Z-2.7639 F900
G01 X47.5835 Y23.1129 Z-3.2505 F900
G01 X47.3643 Y23.1316 Z-3.7488 F900
G01 X47.2547 Y23.1410 Z-4.0000 F900
G01 X47.1455 Y23.1540 Z-4.2512 F900
G01 X46.9271 Y23.1802 Z-4.7495 F900
G01 X46.7086 Y23.2064 Z-5.2361 F900
G01 X46.4902 Y23.2326 Z-5.7031 F900
G01 X46.3446 Y23.2501 Z-6.0000 F900
G01 X46.2721 Y23.2613 Z-6.1433 F900
G01 X46.0547 Y23.2949 Z-6.5497 F900
G01 X45.8373 Y23.3285 Z-6.9159 F900
G01 X45.6199 Y23.3621 Z-7.2361 F900
G01 X45.4387 Y23.3901 Z-7.4641 F900
G01 X45.4027 Y23.3970 Z-7.5052 F900
G01 X45.1865 Y23.4380 Z-7.7191 F900
G01 X44.9704 Y23.4790 Z-7.8743 F900
G01 X44.7543 Y23.5200 Z-7.9685 F900
G01 X44.5381 Y23.5610 Z-8.0000 F900
G01 X44.7543 Y76.4800 Z-7.9685 F900
G01 X44.9704 Y76.5210 Z-7.8743 F900
G01 X45.1865 Y76.5620 Z-7.7191 F900
G01 X45.4027 Y76.6030 Z-7.5052 F900
G01 X45.4387 Y76.6099 Z-7.4641 F900
G01 X45.6199 Y76.6379 Z-7.2361 F900
G01 X45.8373 Y76.6715 Z-6.9159 F900
G01 X46.0547 Y76.7051 Z-6.5497 F900
G01 X46.2721 Y76.7387 Z-6.1433 F900
G01 X46.3446 Y76.7499 Z-6.0000 F900
G01 X46.4902 Y76.7674 Z-5.7031 F900
G01 X46.7086 Y76.7936 Z-5.2361 F900
G01 X46.9271 Y76.8198 Z-4.7495 F900
G01 X47.1455 Y76.8459 Z-4.2512 F900
G01 X47.2547 Y76.8590 Z-4.0000 F900
G01 X47.3643 Y76.8684 Z-3.7488 F900
G01 X47.5835 Y76.8871 Z-3.2505 F900
G01 X47.8027 Y76.9059 Z-2.7639 F900
G01 X48.0219 Y76.9246 Z-2.2969 F900
G01 X48.1680 Y76.9371 Z-2.0000 F900
G01 X48.2413 Y76.9408 Z-1.8567 F900
G01 X48.4610 Y76.9521 Z-1.4503 F900
G01 X48.6807 Y76.9633 Z-1.0841 F900
G01 X48.9004 Y76.9745 Z-0.7639 F900
G01 X49.0835 Y76.9839 Z-0.5359 F900
G01 X49.1202 Y76.9845 Z-0.4948 F900
G01 X49.3401 Y76.9883 Z-0.2809 F900
G01 X49.5601 Y76.9920 Z-0.1257 F900
G01 X49.7800 Y76.9958 Z-0.0315 F900
G01 X50.2200 Y76.9958 Z-0.0315 F900
G01 X50.4399 Y76.9920 Z-0.1257 F900
G01 X50.6599 Y76.9883 Z-0.2809 F900
G01 X50.8799 Y76.9845 Z-0.4948 F900
G01 X50.9165 Y76.9839 Z-0.5359 F900
G01 X51.0996 Y76.9745 Z-0.7639 F900
G01 X51.3193 Y76.9633 Z-1.0841 F900
G01 X51.5390 Y76.9521 Z-1.4503 F900
G01 X51.7587 Y76.9408 Z-1.8567 F900
G01 X51.8320 Y76.9371 Z-2.0000 F900
G01 X51.9781 Y76.9246 Z-2.2969 F900
G01 X52.1973 Y76.9059 Z-2.7639 F900
G01 X52.4165 Y76.8871 Z-3.2505 F900
G01 X52.6357 Y76.8684 Z-3.7488 F900
G01 X52.7453 Y76.8590 Z-4.0000 F900
G01 X52.8545 Y76.8459 Z-4.2512 F900
G01 X53.0729 Y76.8198 Z-4.7495 F900
G01 X53.2914 Y76.7936 Z-5.2361 F900
G01 X53.5098 Y76.7674 Z-5.7031 F900
G01 X53.6554 Y76.7499 Z-6.0000 F900
G01 X53.7279 Y76.7387 Z-6.1433 F900
G01 X53.9453 Y76.7051 Z-6.5497 F900
G01 X54.1627 Y76.6715 Z-6.9159 F900
G01 X54.3801 Y76.6379 Z-7.2361 F900
G01 X54.5613 Y76.6099 Z-7.4641 F900
G01 X54.5973 Y76.6030 Z-7.5052 F900
G01 X54.8135 Y76.5620 Z-7.7191 F900
G01 X55.0296 Y76.5210 Z-7.8743 F900
G01 X55.2457 Y76.4800 Z-7.9685 F900
G01 X55.4619 Y76.4390 Z-8.0000 F900
G01 X55.2457 Y23.5200 Z-7.9685 F900
G01 X55.0296 Y23.4790 Z-7.8743 F900
G01 X54.8135 Y23.4380 Z-7.7191 F900
G01 X54.5973 Y23.3970 Z-7.5052 F900
G01 X54.5613 Y23.3901 Z-7.4641 F900
G01 X54.3801 Y23.3621 Z-7.2361 F900
G01 X54.1627 Y23.3285 Z-6.9159 F900
G01 X53.9453 Y23.2949 Z-6.5497 F900
G01 X53.7279 Y23.2613 Z-6.1433 F900
G01 X53.6554 Y23.2501 Z-6.0000 F900
G01 X53.5098 Y23.2326 Z-5.7031 F900
G01 X53.2914 Y23.2064 Z-5.2361 F900
G01 X53.0729 Y23.1802 Z-4.7495 F900
G01 X52.8545 Y23.1540 Z-4.2512 F900
G01 X52.7453 Y23.1410 Z-4.0000 F900
G01 X52.6357 Y23.1316 Z-3.7488 F900
G01 X52.4165 Y23.1129 Z-3.2505 F900
G01 X52.1973 Y23.0941 Z-2.7639 F900
G01 X51.9781 Y23.0754 Z-2.2969 F900
G01 X51.8320 Y23.0629 Z-2.0000 F900
G01 X51.7587 Y23.0592 Z-1.8567 F900
G01 X51.5390 Y23.0479 Z-1.4503 F900
G01 X51.3193 Y23.0367 Z-1.0841 F900
G01 X51.0996 Y23.0254 Z-0.7639 F900
G01 X50.9165 Y23.0161 Z-0.5359 F900
G01 X50.8799 Y23.0155 Z-0.4948 F900
G01 X50.6599 Y23.0117 Z-0.2809 F900
G01 X50.4399 Y23.0080 Z-0.1257 F900
G01 X50.2200 Y23.0042 Z-0.0315 F900
G01 X49.7800 Y23.0042 Z-0.0473 F900
G01 X49.5601 Y23.0080 Z-0.1885 F900
G01 X49.3401 Y23.0117 Z-0.4213 F900
G01 X49.1202 Y23.0155 Z-0.7422 F900
G01 X49.0835 Y23.0161 Z-0.8038 F900
G01 X48.9004 Y23.0254 Z-1.1459 F900
G01 X48.6807 Y23.0367 Z-1.6262 F900
G01 X48.4610 Y23.0479 Z-2.1755 F900
G01 X48.2413 Y23.0592 Z-2.7850 F900
G01 X48.1680 Y23.0629 Z-3.0000 F900
G01 X48.0219 Y23.0754 Z-3.4453 F900
G01 X47.8027 Y23.0941 Z-4.1459 F900
G01 X47.5835 Y23.1129 Z-4.8757 F900
G01 X47.3643 Y23.1316 Z-5.6233 F900
G01 X47.2547 Y23.1410 Z-6.0000 F900
G01 X47.1455 Y23.1540 Z-6.3767 F900
G01 X46.9271 Y23.1802 Z-7.1243 F900
G01 X46.7086 Y23.2064 Z-7.8541 F900
G01 X46.4902 Y23.2326 Z-8.5547 F900
G01 X46.3446 Y23.2501 Z-9.0000 F900
G01 X46.2721 Y23.2613 Z-9.2150 F900
G01 X46.0547 Y23.2949 Z-9.8245 F900
G01 X45.8373 Y23.3285 Z-10.3738 F900
G01 X45.6199 Y23.3621 Z-10.8541 F900
G01 X45.4387 Y23.3901 Z-11.1962 F900
G01 X45.4027 Y23.3970 Z-11.2578 F900
G01 X45.1865 Y23.4380 Z-11.5787 F900
G01 X44.9704 Y23.4790 Z-11.8115 F900
G01 X44.7543 Y23.5200 Z-11.9527 F900
G01 X44.5381 Y23.5610 Z-12.0000 F900
G01 X44.7543 Y76.4800 Z-11.9527 F900
G01 X44.9704 Y76.5210 Z-11.8115 F900
G01 X45.1865 Y76.5620 Z-11.5787 F900
G01 X45.4027 Y76.6030 Z-11.2578 F900
G01 X45.4387 Y76.6099 Z-11.1962 F900
G01 X45.6199 Y76.6379 Z-10.8541 F900
G01 X45.8373 Y76.6715 Z-10.3738 F900
G01 X46.0547 Y76.7051 Z-9.8245 F900
G01 X46.2721 Y76.7387 Z-9.2150 F900
G01 X46.3446 Y76.7499 Z-9.0000 F900
G01 X46.4902 Y76.7674 Z-8.5547 F900
G01 X46.7086 Y76.7936 Z-7.8541 F900
G01 X46.9271 Y76.8198 Z-7.1243 F900
G01 X47.1455 Y76.8459 Z-6.3767 F900
G01 X47.2547 Y76.8590 Z-6.0000 F900
G01 X47.3643 Y76.8684 Z-5.6233 F900
G01 X47.5835 Y76.8871 Z-4.8757 F900
G01 X47.8027 Y76.9059 Z-4.1459 F900
G01 X48.0219 Y76.9246 Z-3.4453 F900
G01 X48.1680 Y76.9371 Z-3.0000 F900
G01 X48.2413 Y76.9408 Z-2.7850 F900
G01 X48.4610 Y76.9521 Z-2.1755 F900
G01 X48.6807 Y76.9633 Z-1.6262 F900
G01 X48.9004 Y76.9745 Z-1.1459 F900
G01 X49.0835 Y76.9839 Z-0.8038 F900
G01 X49.1202 Y76.9845 Z-0.7422 F900
G01 X49.3401 Y76.9883 Z-0.4213 F900
G01 X49.5601 Y76.9920 Z-0.1885 F900
G01 X49.7800 Y76.9958 Z-0.0473 F900
G01 X50.2200 Y76.9958 Z-0.0473 F900
G01 X50.4399 Y76.9920 Z-0.1885 F900
G01 X50.6599 Y76.9883 Z-0.4213 F900
G01 X50.8799 Y76.9845 Z-0.7422 F900
G01 X50.9165 Y76.9839 Z-0.8038 F900
G01 X51.0996 Y76.9745 Z-1.1459 F900
G01 X51.3193 Y76.9633 Z-1.6262 F900
G01 X51.5390 Y76.9521 Z-2.1755 F900
G01 X51.7587 Y76.9408 Z-2.7850 F900
G01 X51.8320 Y76.9371 Z-3.0000 F900
G01 X51.9781 Y76.9246 Z-3.4453 F900
G01 X52.1973 Y76.9059 Z-4.1459 F900
G01 X52.4165 Y76.8871 Z-4.8757 F900
G01 X52.6357 Y76.8684 Z-5.6233 F900
G01 X52.7453 Y76.8590 Z-6.0000 F900
G01 X52.8545 Y76.8459 Z-6.3767 F900
G01 X53.0729 Y76.8198 Z-7.1243 F900
G01 X53.2914 Y76.7936 Z-7.8541 F900
G01 X53.5098 Y76.7674 Z-8.5547 F900
G01 X53.6554 Y76.7499 Z-9.0000 F900
G01 X53.7279 Y76.7387 Z-9.2150 F900
G01 X53.9453 Y76.7051 Z-9.8245 F900
G01 X54.1627 Y76.6715 Z-10.3738 F900
G01 X54.3801 Y76.6379 Z-10.8541 F900
G01 X54.5613 Y76.6099 Z-11.1962 F900
G01 X54.5973 Y76.6030 Z-11.2578 F900
G01 X54.8135 Y76.5620 Z-11.5787 F900
G01 X55.0296 Y76.5210 Z-11.8115 F900
G01 X55.2457 Y76.4800 Z-11.9527 F900
G01 X55.4619 Y76.4390 Z-12.0000 F900
G01 X55.2457 Y23.5200 Z-11.9527 F900
G01 X55.0296 Y23.4790 Z-11.8115 F900
G01 X54.8135 Y23.4380 Z-11.5787 F900
G01 X54.5973 Y23.3970 Z-11.2578 F900
G01 X54.5613 Y23.3901 Z-11.1962 F900
G01 X54.3801 Y23.3621 Z-10.8541 F900
G01 X54.1627 Y23.3285 Z-10.3738 F900
G01 X53.9453 Y23.2949 Z-9.8245 F900
G01 X53.7279 Y23.2613 Z-9.2150 F900
G01 X53.6554 Y23.2501 Z-9.0000 F900
G01 X53.5098 Y23.2326 Z-8.5547 F900
G01 X53.2914 Y23.2064 Z-7.8541 F900
G01 X53.0729 Y23.1802 Z-7.1243 F900
G01 X52.8545 Y23.1540 Z-6.3767 F900
G01 X52.7453 Y23.1410 Z-6.0000 F900
G01 X52.6357 Y23.1316 Z-5.6233 F900
G01 X52.4165 Y23.1129 Z-4.8757 F900
G01 X52.1973 Y23.0941 Z-4.1459 F900
G01 X51.9781 Y23.0754 Z-3.4453 F900
G01 X51.8320 Y23.0629 Z-3.0000 F900
G01 X51.7587 Y23.0592 Z-2.7850 F900
G01 X51.5390 Y23.0479 Z-2.1755 F900
G01 X51.3193 Y23.0367 Z-1.6262 F900
G01 X51.0996 Y23.0254 Z-1.1459 F900
G01 X50.9165 Y23.0161 Z-0.8038 F900
G01 X50.8799 Y23.0155 Z-0.7422 F900
G01 X50.6599 Y23.0117 Z-0.4213 F900
G01 X50.4399 Y23.0080 Z-0.1885 F900
G01 X50.2200 Y23.0042 Z-0.0473 F900
G01 X49.7800 Y23.0042 Z-0.0631 F900
G01 X49.5601 Y23.0080 Z-0.2513 F900
G01 X49.3401 Y23.0117 Z-0.5618 F900
G01 X49.1202 Y23.0155 Z-0.9895 F900
G01 X49.0835 Y23.0161 Z-1.0718 F900
G01 X48.9004 Y23.0254 Z-1.5279 F900
G01 X48.6807 Y23.0367 Z-2.1683 F900
G01 X48.4610 Y23.0479 Z-2.9006 F900
G01 X48.2413 Y23.0592 Z-3.7134 F900
G01 X48.1680 Y23.0629 Z-4.0000 F900
G01 X48.0219 Y23.0754 Z-4.5938 F900
G01 X47.8027 Y23.0941 Z-5.5279 F900
G01 X47.5835 Y23.1129 Z-6.5009 F900
G01 X47.3643 Y23.1316 Z-7.4977 F900
G01 X47.2547 Y23.1410 Z-8.0000 F900
G01 X47.1455 Y23.1540 Z-8.5023 F900
G01 X46.9271 Y23.1802 Z-9.4991 F900
G01 X46.7086 Y23.2064 Z-10.4721 F900
G01 X46.4902 Y23.2326 Z-11.4062 F900
G01 X46.3446 Y23.2501 Z-12.0000 F900
G01 X46.2721 Y23.2613 Z-12.2866 F900
G01 X46.0547 Y23.2949 Z-13.0994 F900
G01 X45.8373 Y23.3285 Z-13.8317 F900
G01 X45.6199 Y23.3621 Z-14.4721 F900
G01 X45.4387 Y23.3901 Z-14.9282 F900
G01 X45.4027 Y23.3970 Z-15.0105 F900
G01 X45.1865 Y23.4380 Z-15.4382 F900
G01 X44.9704 Y23.4790 Z-15.7487 F900
G01 X44.7543 Y23.5200 Z-15.9369 F900
G01 X44.5381 Y23.5610 Z-16.0000 F900
G01 X44.7543 Y76.4800 Z-15.9369 F900
G01 X44.9704 Y76.5210 Z-15.7487 F900
G01 X45.1865 Y76.5620 Z-15.4382 F900
G01 X45.4027 Y76.6030 Z-15.0105 F900
G01 X45.4387 Y76.6099 Z-14.9282 F900
G01 X45.6199 Y76.6379 Z-14.4721 F900
G01 X45.8373 Y76.6715 Z-13.8317 F900
G01 X46.0547 Y76.7051 Z-13.0994 F900
G01 X46.2721 Y76.7387 Z-12.2866 F900
G01 X46.3446 Y76.7499 Z-12.0000 F900
G01 X46.4902 Y76.7674 Z-11.4062 F900
G01 X46.7086 Y76.7936 Z-10.4721 F900
G01 X46.9271 Y76.8198 Z-9.4991 F900
G01 X47.1455 Y76.8459 Z-8.5023 F900
G01 X47.2547 Y76.8590 Z-8.0000 F900
G01 X47.3643 Y76.8684 Z-7.4977 F900
G01 X47.5835 Y76.8871 Z-6.5009 F900
G01 X47.8027 Y76.9059 Z-5.5279 F900
G01 X48.0219 Y76.9246 Z-4.5938 F900
G01 X48.1680 Y76.9371 Z-4.0000 F900
G01 X48.2413 Y76.9408 Z-3.7134 F900
G01 X48.4610 Y76.9521 Z-2.9006 F900
G01 X48.6807 Y76.9633 Z-2.1683 F900
G01 X48.9004 Y76.9745 Z-1.5279 F900
G01 X49.0835 Y76.9839 Z-1.0718 F900
G01 X49.1202 Y76.9845 Z-0.9895 F900
G01 X49.3401 Y76.9883 Z-0.5618 F900
G01 X49.5601 Y76.9920 Z-0.2513 F900
G01 X49.7800 Y76.9958 Z-0.0631 F900
G01 X50.2200 Y76.9958 Z-0.0631 F900
G01 X50.4399 Y76.9920 Z-0.2513 F900
G01 X50.6599 Y76.9883 Z-0.5618 F900
G01 X50.8799 Y76.9845 Z-0.9895 F900
G01 X50.9165 Y76.9839 Z-1.0718 F900
G01 X51.0996 Y76.9745 Z-1.5279 F900
G01 X51.3193 Y76.9633 Z-2.1683 F900
G01 X51.5390 Y76.9521 Z-2.9006 F900
G01 X51.7587 Y76.9408 Z-3.7134 F900
G01 X51.8320 Y76.9371 Z-4.0000 F900
G01 X51.9781 Y76.9246 Z-4.5938 F900
G01 X52.1973 Y76.9059 Z-5.5279 F900
G01 X52.4165 Y76.8871 Z-6.5009 F900
G01 X52.6357 Y76.8684 Z-7.4977 F900
G01 X52.7453 Y76.8590 Z-8.0000 F900
G01 X52.8545 Y76.8459 Z-8.5023 F900
G01 X53.0729 Y76.8198 Z-9.4991 F900
G01 X53.2914 Y76.7936 Z-10.4721 F900
G01 X53.5098 Y76.7674 Z-11.4062 F900
G01 X53.6554 Y76.7499 Z-12.0000 F900
G01 X53.7279 Y76.7387 Z-12.2866 F900
G01 X53.9453 Y76.7051 Z-13.0994 F900
G01 X54.1627 Y76.6715 Z-13.8317 F900
G01 X54.3801 Y76.6379 Z-14.4721 F900
G01 X54.5613 Y76.6099 Z-14.9282 F900
G01 X54.5973 Y76.6030 Z-15.0105 F900
G01 X54.8135 Y76.5620 Z-15.4382 F900
G01 X55.0296 Y76.5210 Z-15.7487 F900
G01 X55.2457 Y76.4800 Z-15.9369 F900
G01 X55.4619 Y76.4390 Z-16.0000 F900
←-cut code –>
G01 X48.0206 Y-2.9585 Z-5.4551 F900
G01 X48.2404 Y-2.9672 Z-4.4096 F900
G01 X48.4603 Y-2.9758 Z-3.4445 F900
G01 X48.6251 Y-2.9823 Z-2.7825 F900
G01 X48.6801 Y-2.9830 Z-2.5748 F900
G01 X48.9001 Y-2.9859 Z-1.8143 F900
G01 X49.1201 Y-2.9888 Z-1.1751 F900
G01 X49.3401 Y-2.9916 Z-0.6671 F900
G01 X49.5600 Y-2.9945 Z-0.2985 F900
G01 X49.7800 Y-2.9974 Z-0.0749 F900
G01 X50.0000 Y-3.0003 Z0.0000 F900
G00 Z5.0000 F900
G00 X0.0000 Y0.0000 F2400
M107 ; Turn off IOT Relay
G28 Z ; Lift Z axis
M0 Diggidy Done! ; Pause to keep steppers energized
Had to cut some of the code in the middle of the job due to message size limits.
That G38.2 command should include a negative Z value to specify the max distance it should probe. You should get rid of the G92 after it and instead have a P13 in the G38.2 command. I’m guessing its not getting zeroed right so that G1 Z30 isn’t doing what you are expecting.
You’re also missing some important starting gcode to set some default values. Check out the starting gcode in milling basics.
Thanks Jason for those pointers. I did the changes talked about on the milling basics page and it seems to be working as expected now again. I suppose the questions is how did it work before?
Cut 4 rings last night and they all worked fine.
I’m not certain but it could have been some of the other starting gcode. For example, G20 sets the units to metric. So, if you ran a previous script with G21, it could still be in inches. Or if it was left in G91, that could do weird things. But now the script should be resetting things like that.
