Hello, a little help please. I did some work on Aspire and when the Spindle start go to zero Z and do a small hole on the wood. I don’t see that movement on the gcode. Maybe some adjustment on z? Thanks
Jose,
After you home the Z axis, you need to then move the bit to the surface of the work piece and set the Z axis to zero.
This is explained in the documentation:
https://docs.v1e.com/learn/coordinates/
Mike
Also, check and make sure the setting is “top of block” for origin
Thanks for your help.
