You can just swap the Z motor cable around on one end:
Strange. I am going to flip it.
But just for my peace of mind - this would theoritically right (see pic).
Visually but you need the schematic to be sure. The symptoms suggest otherwise Jeffeb3 is correct
Can the marlin menu be changed to have main level options for âHome XYâ and âHome Zâ to replace the current âHome Allâ option?
Yee-eesss⌠But it would involve mucking about in the firmware source. I donât think it would be terribly difficult, the menu code looked pretty modular when I checked it out. But youâd have to figure out a way to stash and reapply your changes every time thereâs an update you wantâŚ
Regarding changing the home behavior:
The LCD function for that home sequence is the same as sending G28 via the command line. Another option, which would be a more universal solution, is to change the default bahavior of G28 to only home XY. Then youâd be able to send G28, and then G28 Z to do the touch plate.
That would have the advantage of making things like the home all button in repetier host play nice with our machines too.
I remember a config parameter for what the default homing sequence was. I am just not sure If I saw that in grbl or in Marlinâs config.
It is impossible to tell from the wire colors. The motor manifacturers choose whatever wires they want, and wire them how they want. The proof is in the pudding, and if it is moving the wrong direction, then you should swap the cable around.
It is a pretty common problem and solution.
Just make sure the control board is powered off before plugging or unplugging the motors.
And thus answered one question for me. Flipping Connector => now it works.
That leaves another question that has actually already been answered.
Iâm just surprised what you can still do with the G38.x? At least it is directly contained in cncjs and promises nice solutions.
But this command does not seem to work at all, does it?
It would still be a great thing if I could use the Z-end sensor and the measuring device?
Iâm only asking because it is explicitly available everywhere and is mentioned again and again in the many videos and instructions. I canât be the only one who stumbles upon it here, can I?
I thought it was pretty obscure. You can enable it in the configuration of marlin.
What software is that?
That is cncjs
