X axis issue de energizing
power on machine , all motors energize
if X is within 100mm of home it homes okay .
than say i send it to X1200 no issues , than send it to X10 it travels sweet back to about X 300 than starts to shudder like its catching on some thing, than X motor de energizes.
have put air gun in around gantry bearings incase some chips in there
have even changed driver on X and still the same issue .
If i flick mains off and back on straight away X re energizes
No errors coining up in terminal
have removed power from wall left it for half hr same issues
any ideas on what could be
EDIT: now when power on still energizes but as soon as i click home X it deenergizes
<Idle|MPos:0.000,0.000,0.000|FS:0,0>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:3.000,3.000,-76.600>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
$SS
[MSG:INFO: FluidNC v3.9.9 https://github.com/bdring/FluidNC]
[MSG:INFO: Machine LowRider]
[MSG:INFO: I2SO BCK:gpio.22 WS:gpio.17 DATA:gpio.21Min Pulse:2us]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110]
[MSG:INFO:  Neg Limit gpio.25]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110]
[MSG:INFO:  Neg Limit gpio.33]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110]
[MSG:INFO:  Neg Limit gpio.35]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110]
[MSG:INFO:  Pos Limit gpio.32]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110]
[MSG:INFO:  Pos Limit gpio.34]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low]
ok
just clicked home all X was at about X600 it got to about X 300 than turned round went to about x 400 than back to 330 than back to 400 than went to about X100 and stopped , still doing the grinding noise
swapped X and Y0 drivers , Y axis move as should X still deenergizes
even swapped out esp which still has 3.9.1 loaded on it , homed better than version 3.9.9 ran to X1200 sweet than got back to about X 300 and started to bind again
currentlly pulling apart core to see if anything lodged in there to cause it to bind
it was actually amazing how much build up was in bottom of core bearing housing , after a good clean out and new bearings X axis is a lot smoother and quieter :slight_smile:
still had same problem when moving Xaxis as above ,
after playing around with the wires found a bad spot mid way along extension cable
replaced extension cable and all good to go again :smiley:
