Finished my video. Added content to cover standard and custom struts, cuts and more. Hope this helps folks figuring out whether, and how to build their LowRider 3!
@vicious1, please let me know if I’ve inappropriately, overly misused V1E content.
Feedback appreciated, cheers!
00:00 - Intro and video goals
00:48 - WHAT’s a LowRider CNC for? Answer: Subtractive Manufacturing
01:30 - WHY build a LowRider? Answer: Step up from my baby CNC, right balance of quality and price for me.
02:20 - MPCNC is good, but I want a LowRider 3
02:43 - Pick your own size, or sizes even…
04:51 - Using Controller+TFT case by V1E Community member Doug Joseph
04:55 - Hassle free kits and parts available from https://shop.v1engineering.com, Controllers come with software preloaded.
05:48 - Parts printed, milled and delivered
06:24 - Unboxing V1E LowRider 3 Kit. Woot!
06:28 - Assemble LR3 Core
06:36 - Ream holes, reverse drill helps screws slip in tight
06:54 - Assemble X Drive
07:12 - Mount X Drive
07:15 - Stare at your Core for a bit, it’s so pretty
07:16 - Mount X endstop to Core
07:25 - Assemble Y Steppers
07:51 - Soldered Z endstops, too tight for spade connectors
07:56 - XZ Lead screw stubs. Reverse drill with 13/32 bit
08:02 - Assemble XZ plates
08:24 - Marry XZ to YZ plates
08:34 - Marry XZ to YZ plate rails
08:45 - Mount Z drive to YZ plate
08:55 - Wiring Z endstops, solder
09:03 - Wiring Z endstops, test
09:08 - Assemble Z endstops
09:16 - Mount Z endstops
09:18 - Adjust XZ plate, was binding
09:26 - Mount Z endstops
09:31 - Mount Y Drive
09:42 - Wiring Y endstop, solder
09:50 - Mount Y endstop, wiring routing
09:55 - Wiring routing
09:57 - Mount Y endstop, wiring routing
10:00 - Assemble wheels
10:05 - Mount wheels to YZ plate
10:10 - Assemble and mount Rail Rollers
10:19 - Assemble Beam, strut order… 1) Front, 2) Bottom, 3) Back
10:21 - mount braces
10:25 - LR3 Calculator, pipe and table size
10:28 - Front, loosely insert screws
10:36 - Bottom, loosely insert screws
10:41 - Rear, loosely insert screws
10:51 - Front, check straight, snug clamps
10:58 - Mount core
11:00 - Mount YZ plate
11:10 - Assemble X Belt
11:10 - Insert X Belt
11:12 - Mount X Belt holder
11:15 - Check X Belt end not blocking Z axis motion
11:17 - Mount X belt tensioner
11:28 - Fix for if X Belt stub is too loose
11:31 - Attach PETG tool mount
11:38 - Attach Vac hose mount
11:40 - Wiring SKR Pro 1.2 Controller
11:40 - Bend/clip diag driver pin
11:45 - Change jumpers
11:48 - Mount drivers
11:54 - Remove JST shields
12:03 - TMC2209 driver pinouts
12:05 - Wiring 〉 Route and Sleeve (1/2" wrap)
12:05 - Left YZ sleeve
12:15 - Routing right YZ
12:24 - Extend right YZ, use solder butt connectors
12:54 - Right YZ, 1/2" sleeve wrap
12:59 - NOT using cable gland, case holes too small
13:05 - Extend wires for X axis
13:16 - Wire X axis, test endstop
13:23 - Wire X axis routing and 1/2" sleeve
13:46 - X axis, verify range of motion. Router cord blockage
14:06 - Wire X axis, cable management
14:20 - Case wiring, routing power
14:42 - Controller wiring, driver endstops
15:03 - Wiring controller, fans and TFT
15:37 - Build minimum viable Sled. Use LR3 Sled edition to finish LR3!
17:12 - Motion test, FAIL - Y stepper wiring reversed
17:21 - Motion test, SUCCESS - Homed and move as expected
17:28 - Crown Test, SUCCESS, kinda…
17:47 - Struts 〉 Initial squaring
17:48 - Attach pen to Core
17:50 - Generate test gcode
17:51 - Connect via Repetier
17:53 - FAIL, relative positioning was set
17:54 - Typed gcode for corner moves
18:02 - Measure squareness
18:05 - Config homing offsets M666
18:07 - Z Leveling
18:19 - Struts 〉 Design
Calc size, download files
Use OpenScad & Estlcam to prepare gcode
18:31 - Struts 〉 First cut ~56mins
18:31 - Fasten spoilboard and stock
18:40 - Cut first strut
18:47 - Post cleanup, too long
18:54 - Struts 〉 Second cut ~42mins
19:02 - Post cleanup, Remove/trim debris, sand, vac
19:09 - Paint it black
19:16 - Surfacing Spoilboard
19:16 - Create toolpath
19:17 - Cut ~0.5mm in ~61mins
19:25 - Struts 〉 Make custom front strut
19:25 - OpenScad 〉 Customize, export .SVG
19:26 - Estlcam 〉 Create and Preview toolpaths
19:28 - Repetier 〉 Load .gcode
19:28 - Carve and cut 42mins
19:35 - Struts 〉 Paint 〉 2nd coat, protect via Shellac/Polycrylic
19:37 - Final Assembly - Mount struts to beam
19:40 - Temporarily disassemble beam
19:57 - Mount bottom strut
20:02 - Mount front strut
20:07 - Mount YZ plates and rear strut
20:17 - Wrap up
Future upgrades - Table, Vac, drag chain and more…
Check out https://forum.v1engineering.com
Thank you! Want to see more?
