The stand
Just messing around with the toys…
Nice! That is a pretty slick setup.
I’m chewing on how to organize my woodshop, including what kind of benches to make. Maybe I should just put each tool on it’s own one of these :slight_smile: . It would be pretty funny to see my benchtop drillpress on something like that (until it fell over and hurt someone).
Next step is servos to move it around… And maybe another leg so it doesn’t have to hop to get around.
My grandfather had an old bench grinder mounted to the end of an axle that was bolted to a tireless rim… You can make a stand out of anything.
The laptop stand is pretty slick. You should add a camera so that it can rotate so the screen is always facing you while you walk around. Auto-zooming software to make the text larger the farther you walk away :slight_smile:
Bolt it to the floor. My drill press is lagged to the floor of my shop. Helps that my floor is wood, but concrete anchors are pretty easy to work with.
