It’s time! I’ve put off actually putting this thing in the freezer for reasons I cannot determine but I’ve got a job on deck that I’d like to be as perfect as I can get it so it’s about time this bad boy felt the chill.
Running a full test air cut outside of the freezer to make sure I know how this machine runs when it’s not cold. It’s a good opportunity to post here and then enjoy my lunch before suiting up. I’ll take pics of the setup and post and then process pics of the cut.
One thing that’ll likely jump out at everyone - the orange router. I bought it off Vevor to see what it was like and it’s an exact replica of the Makitas but way cheaper like $65CDN I’ll let you know how it performs
Here is the step by step assembly. You’ll notice it’s in good company with Bumble in the background. I just need to give it maybe a half hour now to cool down so I can check all the important PLA bits. It shrinks quite a lot when it is below zero. (That’s what I tell her anyway. ) Also if I put the slab of ice onto the warm wood base it’ll melt just enough to freeze down and make more work for me later.
Super success here. I was contemplating why it’s taken me so long to get this machine into the freezer. I think I was scared it might not work as planned. But holy cow V1 wins once again! I have never been so proud as I was watching this run. I remember watching the giant MPCNC run and it was equally as cool but this was incredible. And so much easier to keep the moving parts blown off compared to the MPCNC.
It’s super hard to see but stay tuned. The next step is to fill the void up with super fine snow. I’ll make that tomorrow morning.
I’m curious - do you ever dye or color the snow before packing it in the crevices? I’m guessing the colors would run as things started to melt, but I’d be interested in seeing the effect.
Apologies for the gap here - forgot to keep the thread rolling.
There are two schools when it comes to getting color into the ice. Well, three. Some use colored sand, mixed with cold water so it can “flow” into the voids. Some use a clever mix of tempera paints and gelatin to make a “gummy” insert. And some, like me try to use waterproofed prints wherever possible because no matter what, these won’t bleed out or degrade as the sculpture melts.
Here are a few shorts of the machine doing it’s thing. I’ve just completed the second sculpture using the LR3 and plan on a whole lot of playing around this coming week.
I’m finally using this bad boy for its second function in portability. Instead of lifting the ice up to the machine I can drop the machine down to the ice. So much easier on my back! And this particular job has seven pieces to machine!
I’ll get pics of the project installed Saturday but for now there will be a few from the freezer.
I’m back at it in a very crowded freezer - but the LR3 still fits! I realized I hadn’t posted photos of the result from the last post. Every detail you see in the photo was created by the LR3. These photos are from the end of the event just prior to removal. The bride was still at the party so I gave her the honors…
Finally getting around to this. I’m tired of jumping in and out of the freezer when setting machine up, jogging, running etc. I’ll see how this performs in the cold and if need be maybe add some sort of heat source to the case to be printed still.
Holy cow! Was that ever an easy setup. Bravo Jason! I haven’t confirmed it’s working just yet but have no reason to believe it won’t. You made this ridiculously easy.
