I’ve been struggling with some issues that I thought were Estlcam completing tool paths ( Estlcam has some occasional mis-moves - is it my source image, my MPCNC, or engraving settings? - #45 by vicious1 )
I still suspect that maybe belt tension is at issue. I’ve set tension by twanging and also by using a pretty sensitive sax tuner app to get the actual sound frequency of each section of belt and adjust them so they are within 1-2hz of each other. I’m still seeing my issues, so I was wondering if there was an SVG I could make into a tool path that helps me identify which tensioners need to be loosened or tightened.
I’m using a Primo with dual endstops, if it makes a difference for testing.
Does such a calibration or test pattern exist?
