Hello everyone,
I am using a 12V 6A power supply, I set the Drv8825 driver current to 0.7 and put three jumpers under the driver.
The motor model I am using is: 17HS13-0404S from oyostepper
, step angle 1.8, size 48, rated current (A) 1.7OHM 1.8MH 3.2, holding torque 52, positioning torque 2.6
I edited two lines in the code:
#define DEFAULT_AXIS_STEPS_PER_UNIT { 200, 200, 800, 200 }
Replace with:
#define DEFAULT_AXIS_STEPS_PER_UNIT { 100, 100, 800, 100 }
And the bed size:
#define X_BED_SIZE 200
#define Y_BED_SIZE 200
Replace with :
#set X_BED_SIZE 1220
#set Y_BED_SIZE 2440
When I select motion in the LCD options and try to move any axis, the stepper motor vibrates but does not rotate.
What should I do to fix this?
