I just went into the Firmware EEPROM config file and changed them to 100.00 100.00 400.00 and 100.00. I’ll try that and see if that takes care of the problem,
Ok. So somehow that got set to twice as large. Sending this should fix it:
M92 X100 Y100 Z400
Test the motion a little. If that’s right you can save it by sending:
M500
The eeprom settings do the same thing. So that’s a good method too.
I still have some work to do but you put me on the right track I think. I put a job in that was to be 42 in wide and it came back at 21.
Thank you again for your help. I will let you know my results.
