Size of XZ and YZ plates?
You can print standing up on a standard ender3, on a 45-ish degree angle- when you put into Cura and move around, the image style will change when it will fit on plate.
…. Make sure your use a brim of decent perimeter around edges 10 is a good number. It takes a while to print, and can distort without a reasonable surface area on plate. A raft will also work if you have the height available.
Your base looks slightly uneven, but will probably be ok, if both are exactly the same.
Enjoy your build.!:sunglasses:
How has your printing gone overall? Ryan did say in docs, that you should print in the same orientation as he has made, or saved the files.
That is how I did mine, and apart from having to be printing my x carriage 4 times because of various failures, everything else is good.
One tip, after screwing my XY rails to YZ plates, the screws don’t seem to hold well, so when I have cut my plates, i will drill and assemble with screws and nyloc nuts, to hold XY rails to plates .
Trust but verify. I get this is older post, but I am just getting ready to use my LR2 to cut my LR3 XY plate. Any chance you could do a similar measurement on the other plate (XY plate) so i can be sure my CAD has this dialed in before I go to cut? I don’t trust what I see at the first.
