Hello ! I have a MPCNC and i need to cut a lot of pieces in plywood sheet, like in this picture :
But I want to cut Larger piece of plywood, like that i not have to cut my plywood in many part to put on the Cnc machine.
So i want to build a Lowrider. But the fact is that now, to cut the pieces you can see on the picture in a sheet of plywood that is 70cmX70cm, the time of machining is 2 hours.
The best settings i can have with my Mpcnc are : With a 1/8″ bit i can go 2,7mm deep and 13 mm/s speed on the plywood.
The Plywood is 1,5 centimeters thick.
2 Hours of cutting for me, it is a very long time, with the noise and the fact i want to surveil if nothing goes wrong with the CNC.
If i make a Lowrider who can cut sheet of plywood that are 4 times bigger, if the settings are the same than the MPCN, i have 8hours of cutting.
So my questions : Is the Lowrider can cut more deeper, or more quicker than the MPCNC ?
Can i buy something like that for the Lowrider to speed up the process (and reduce the noise) :
Do i need a Lowrider, or if the time of cut is the same, perhaps it is not really necessary to cut bigger sheet of plywood…
Thanks a lot for your advices guys !
