So my kids must of been running around the router. Ended up hitting the 3D printed bracket that the limit switches would make contact too.
Initial thought was just rescrrew it to the side of table but, then I knew I had to make the bump stops the same.
A member mentioned I may need to resquare the gantry to make sure it came off the switches square when machining
What I did
I took my calipers and measured to the back of the stop and from
The face of the bump stop. Made both of them the exact same. Moved it off the stops and then rehomed the Y axis.
What else should I do? Will that correct it enough to use? What test files should I cut and check?
Thanks y’all
Bt
