Q: Do the MOSFETs on the Jackpot need enabled? or are they on by default? A: they're to be switched on!
@vicious1
Hey, on the Jackpot, are the MOSFETs enabled by default, or do they have to be enabled? Mine seem dead. I have wired my 40mm fan to both of them with no response. The little LEDs in front of them are also not lit. ??
They are enabled by gcode. I use one of mine on the Primo to operate a solenoid for my air assist. I didn’t have to enable anything. Lightburn just put it in the gcode automatically since I selected air assist. I would think you could make a macro to turn the fan on. Not sure how to make it do it automatically. That one is above my pay grade LOL
@Jonathjon
OK, thanks. I will await more help while I read through the docs for getting my swapped X and Y configured for Jackpot.
Yes they are triggers, you need to turn them on and off. By default, they are connected to the flood and mist buttons but you can change that.
@DougJoseph
I’m pretty sure all you have to do is swap the x: and y: in the config.yaml.
