I cannot get my heated bed to come on through the matter control interface. if i go to terminal and input M190 S50 it comes on great heats to 50 and then turns off. im at a loss any help would be awesome. here is my config h thermal settings:
//============================= Thermal Settings ============================
- –NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
- Temperature sensors available:
- -4 : thermocouple with AD8495
- -3 : thermocouple with MAX31855 (only for sensor 0)
- -2 : thermocouple with MAX6675 (only for sensor 0)
- -1 : thermocouple with AD595
- 0 : not used
- 1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
- 2 : 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
- 3 : Mendel-parts thermistor (4.7k pullup)
- 4 : 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
- 5 : 100K thermistor - ATC Semitec 104GT-2/104NT-4-R025H42G (Used in ParCan & J-Head) (4.7k pullup)
- 501 : 100K Zonestar (Tronxy X3A) Thermistor
- 6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
- 7 : 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
- 71 : 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
- 8 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
- 9 : 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
- 10 : 100k RS thermistor 198-961 (4.7k pullup)
- 11 : 100k beta 3950 1% thermistor (4.7k pullup)
- 12 : 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup) (calibrated for Makibox hot bed)
- 13 : 100k Hisens 3950 1% up to 300°C for hotend "Simple ONE " & "Hotend “All In ONE”
- 15 : 100k thermistor calibration for JGAurora A5 hotend
- 20 : the PT100 circuit found in the Ultimainboard V2.x
- 60 : 100k Maker’s Tool Works Kapton Bed Thermistor beta=3950
- 66 : 4.7M High Temperature thermistor from Dyze Design
- 70 : the 100K thermistor found in the bq Hephestos 2
- 75 : 100k Generic Silicon Heat Pad with NTC 100K MGB18-104F39050L32 thermistor
- 1k ohm pullup tables - This is atypical, and requires changing out the 4.7k pullup for 1k.
- (but gives greater accuracy and more stable PID)
- 51 : 100k thermistor - EPCOS (1k pullup)
- 52 : 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
- 55 : 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
- 1047 : Pt1000 with 4k7 pullup
- 1010 : Pt1000 with 1k pullup (non standard)
- 147 : Pt100 with 4k7 pullup
- 110 : Pt100 with 1k pullup (non standard)
- Use these for Testing or Development purposes. NEVER for production machine.
- 998 : Dummy Table that ALWAYS reads 25°C or the temperature defined below.
- 999 : Dummy Table that ALWAYS reads 100°C or the temperature defined below.
- :{ ‘0’: “Not used”, ‘1’:“100k / 4.7k - EPCOS”, ‘2’:“200k / 4.7k - ATC Semitec 204GT-2”, ‘3’:“Mendel-parts / 4.7k”, ‘4’:“10k !! do not use for a hotend. Bad resolution at high temp. !!”, ‘5’:“100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)”, ‘501’:“100K Zonestar (Tronxy X3A)”, ‘6’:“100k / 4.7k EPCOS - Not as accurate as Table 1”, ‘7’:“100k / 4.7k Honeywell 135-104LAG-J01”, ‘8’:“100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT”, ‘9’:“100k / 4.7k GE Sensing AL03006-58.2K-97-G1”, ‘10’:“100k / 4.7k RS 198-961”, ‘11’:“100k / 4.7k beta 3950 1%”, ‘12’:“100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)”, ‘13’:“100k Hisens 3950 1% up to 300°C for hotend 'Simple ONE ’ & hotend ‘All In ONE’”, ‘20’:“PT100 (Ultimainboard V2.x)”, ‘51’:“100k / 1k - EPCOS”, ‘52’:“200k / 1k - ATC Semitec 204GT-2”, ‘55’:“100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)”, ‘60’:“100k Maker’s Tool Works Kapton Bed Thermistor beta=3950”, ‘66’:“Dyze Design 4.7M High Temperature thermistor”, ‘70’:“the 100K thermistor found in the bq Hephestos 2”, ‘71’:“100k / 4.7k Honeywell 135-104LAF-J01”, ‘147’:“Pt100 / 4.7k”, ‘1047’:“Pt1000 / 4.7k”, ‘110’:“Pt100 / 1k (non-standard)”, ‘1010’:“Pt1000 / 1k (non standard)”, ‘-4’:“Thermocouple + AD8495”, ‘-3’:“Thermocouple + MAX31855 (only for sensor 0)”, ‘-2’:“Thermocouple + MAX6675 (only for sensor 0)”, ‘-1’:“Thermocouple + AD595”,‘998’:“Dummy 1”, ‘999’:“Dummy 2” }
#define TEMP_SENSOR_0 5
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
#define TEMP_SENSOR_BED 5
#define TEMP_SENSOR_CHAMBER 0
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 100
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 6 // (seconds)
#define TEMP_HYSTERESIS 3 // (degC) range of +/- temperatures considered “close” to the target one
#define TEMP_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 6 // (seconds)
#define TEMP_BED_HYSTERESIS 3 // (degC) range of +/- temperatures considered “close” to the target one
#define TEMP_BED_WINDOW 1 // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define HEATER_4_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but NOT from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define HEATER_4_MAXTEMP 275
#define BED_MAXTEMP 130
thanks in advance. i ran into this problem before but can’t remember the resolution.
