I added that TVS and made all those ESP32 pads oval with 0.9mm holes. I also have the size of the board down to slightly less than 100x100. The ESP32 is centered horizontally but is about 4.5mm off center vertically.
Oh, are you particularly worried about wifi/bluetooth performance on this? If you are, it’s a good idea to make the antenna extend beyond the board.
Otherwise, no drama.
I am not currently using the Wi-Fi or Bluetooth, but that is worth considering moving in case I change my mind later or someone else wants to use this design. I will have to look into that tomorrow. I am probably going to order the specialized parts I need for this before ordering the board just to make sure they will fit correctly. Think I found all the parts on Digikey. Thanks.
I tried moving the ESP32 closer to the edge, but there are just too many traces there to do it. I also tried moving the 2 MAX6675 closer together in the corner by the TFT each on a corner, but I would have had to move the TFT connections too much which I would then have to change the 3D printed electronics case. I am not currently using Wi-Fi, so really not a big deal to me and I am guessing an external antenna might help that. I did move the traces as much out of the way of the end as I could. I put it into Fusion 360 to make sure everything looked reasonable and did have to adjust the SHT31 to match where I had it in the previous design.
Yeah, an external antenna solves that issue.
