One Finn's long build process
Do you mean the struts??
No the triangular braces the struts mount to…
I haven’t seen that done yet. But this is also the first time I have seen the other parts milled out of aluminum
I have had the thought of 3/4 pine before (technically 1x’s)
Exactly. Hmmmm let it see what time will bring :innocent:
I would be worried it would swell and warp with the seasons.
Plywood then?
I did try to find my lr3 limit. I Did not find yet.
6mm one fluted toolbitt.
F 2200 mm/min
Z 20 mm with one pass by full full tool diameter.
Material birchwood.
Rpm Makita dial number 5 (27000 rpm?).
Now swap that with beech and see how far you get with those 20mm. :smiley:
I was picking up some more offcuts from the local fabricator I found and while waiting for them asked what sort of work they did. Turns out they make escape craft for ships. So the aluminium alloy they use (5052) is noted for its higher resistance to galvanic corrosion when being bolted to things like stainless steel.
Now isn’t that handy…
I don’t have beech at hands but how about oak :smirk:?
Hmm are we going to see something interesting soon? :grin:
Not till after the end of the month - self imposed prohibition to focus on the unpleasantly necessary ‘pays the bills’ stuff. :disappointed:
Fellow Finn here, where do you buy your cnc bits? Trying to stock up on some good price/quality toolbits before I take out the LR3 from winter storage…
Moro
I like fraisertools, CMT orangetools and Walthertools. Little expensives but sometimes so worth.
https://www.fraisertools.com/en/
Ps Jos haluat käy täyttää karttakysely V1E sivuilta, luulin että oon ainoo suomesta :smile:
Ready for HALLOWEEN )))
Nah. That machine is ready for a rebuild LOL. But it will have to get put off just a little bit, got 2 more to build and ship in front of it
Terve,
Thanks! I will have a look at these.
Ps. Kiitos, pitää tutkia. Sain tuon LR3 valmiiksi tämän vuoden alkupuolioskolla. Valitettavasti joutui melkein heti varastoon sillä tilaa/aikaa ei riittänyt. Nyt on aikaa perehtyä kunnollisesti itse koneen käyttöön että kesällä voisin jonkun projektin aloittaa.
Mullaki mahtaa mennä taas talveksi säilöö, ellen saa lämpimään tallii :sweat_smile:
Bless you two. Need a tissue? :smiley:
Or was that supposed to be a language (says the German…)? :stuck_out_tongue:
