New to CNC
Other things to think about, if you haven’t already picked up on them in other threads (or your own personal experience):
  • Keep your Z axis as short as you can
  • Get Loctite for your grub screws
  • If you’re set on milling aluminum with endmills, keep it as small as you feasibly can
  • You will likely have better success with some sort of speed control and air assist than any sort of lubrication
  • Loctite + Grub Screws
  • You’re dealing with an unfeeling robot that has a potentially lethal spinning chunk of metal, assume it wants to kill you
  • It’s also got a computer for a brain, assume it knows how to start a fire and will do so as soon as you look away
  • Unless you like chasing oddly stepped shapes, put Loctite on your grub screws
  • If the goat arrives before the initiation instructions, acceptable alternatives and/or inspiration can be found in this thread :candle: :goat: :candle:
  • Did I mention that you might want to consider Loctite on your grub screws? Those buggers have a nasty habit of getting loose and throwing things off
