jeffeb3
(Jeffeb3)
November 25, 2019, 1:31pm
21
https://www.reprap.org/wiki/Archim2
That’s the 2, but the 1 doesn’t show the endstop pins. I am guessing they are the same.
You want to connect (-) to the bit and (s) to the spatula or whatever you’re driving the bit into. Don’t short from (-) to (+). Test with M119 before you try to do a home.
jeffeb3
(Jeffeb3)
November 25, 2019, 1:32pm
22
gwigga
(Robin Morgan)
November 25, 2019, 1:55pm
23
Didn’t even think to look at the 2.0 board, pretty sure its just the drivers that are different between them
gwigga
(Robin Morgan)
November 27, 2019, 8:55am
24
I had confirmation from the people that make the Archim 1.0 that the pins are the same way round as the 2.0 for the end stops
gwigga
(Robin Morgan)
December 7, 2019, 6:04pm
25
So sheds completely insulated now walls and ceiling, and today I built the bench
So all that’s left is to run electrics (in the new year) will run off an extension lead for now, and move the MPCNC out there.
gwigga
(Robin Morgan)
December 9, 2019, 8:44am
26
vicious1
(Ryan)
December 11, 2019, 1:56am
27
Making chips means you are officially part of the crew now!
gwigga
(Robin Morgan)
December 11, 2019, 8:24am
28
Took 6 months but I’m there, time to dial everything in
gwigga
(Robin Morgan)
December 13, 2019, 8:24am
29
SO my little brain has been thinking,
I have a touch plate that does z height
Could I do the same for X and Y using the min pins for those as well, I know I would have to change the direction in marlin so when I send a G28 it moves right instead of left and effectively have 3 touch plates 1 for each axis
jeffeb3
(Jeffeb3)
December 13, 2019, 12:31pm
30
You can. Set the HOME_DIR for XY to +1, then use the xmax and ymax pins.
Then, report back to show off.
gwigga
(Robin Morgan)
December 14, 2019, 3:37pm
31
Video on how I use my touch plate
will
May 11, 2020, 5:59pm
37
Hi Robin,
I’m curious to know what’s the model of your makita router, and what was wrong with the the chinese spindle that made you decide to change?
Thanks, W
