To give more detail. With arcs off the corners are chopped up into tiny tiny straight segments and the SD/LCD can’t feed commands fast enough ( I think). Arcs on, each corner is one command (smooth arc) vs possibly hundreds with them off.
Ok. I’ll give that a try.
No real change. Somehow I ended up with 414 on there for my last project over the weekend. I think it was when I was looking at the controller fan stuff from the old copy where it worked. Now when I enable controller fan, the firmware won’t compile. Whatever. No time for that now.
With arcs, it ran AWFUL… until I noticed the 414 and started scratching my head. Back to the 425, and it ran the same. I played with the junction deviation (0.04 by default) up to 0.1 and the z moves happened a lot faster on my triangular tabs. Min arc length up to 1, nada.
So, when when I send an arc code, the board has to chop it up, right?
Oh yeah, and I think I found my vibration. The rollers (on the side rails) are a bit loose. I still have my first set, and those were loose, too. Then I remembered I was supposed to have some bolts with shoulders. That helped a little, but out came the old tube, and it looks like my DOM is about 0.002 under sized (0.98-1.00). The old mild steel tube was 1.00-1.03.
I’ll definitely pickup the right bolts, and I may print one of the 25mm rollers to see how it fits. I think 0.4mm is just under 0.002", so it should be ok.
Holy cow Turbo! That is incredibly impressive. This is a result I have to live up to.
My business case for this machine is cutting openings for HMI components in electrical control panels, mainly aluminum, but your system gives me hope that one day, maybe, I could cut 12 gauge steel.
I’m gonna be closely following your progress my friend! And maybe asking for advice
Thanks! The steel was kinda slow going. I got a high quality stubby 1/16 mill so I could get a slower speed, but I want to sort out that chatter before trying such a slim tool.
For the record, this build came about because @viciou said he was curious about what the mpcnc could do at a really small size. I was looking for a new project, and boom.
Worth mentioning that I’m still learning, too.
Only thing to really sort out that I don’t understand is those arcs. I can’t cut metal that fast, so it probably doesn’t matter, though. It’s still fast enough that wood won’t burn.
I’ve stored this in my head.
1mm = @ .040” (.03937)
or 0.1mm = .004”, which is the thickness of human hair.
So 0.4mm would be .016”, not .002”.
That’s just in my head.
It’s .0157” if you do the maths. I think you may have a broken decimal point. ![]()
Yep, hit that zero too many times. TWICE. Because 1-0.98 is certainly 0.02, not 0.002. I had it right in my head, at least. What I keep in MY head is that engine pistons are sized by quarter millimeters or ten thou increments for oversizes, and that they are roughly equivalent.
Don’t know what I was doing with that extra 0, lol, but at least 0.4mm IS just under the 0.02 that I want(vs what I typed).
Thanks for helping clean that up, though. I like to imagine that a lot of people are going to read this post over the next ten years, and I’d hate for them to think I’m an idiot.
I know when I was reading it I had to do a double take
Not an idiot, just slow lol
And getting slower all the time!
Slow>wrong.
I’m curious about this, do you use climb or conventional milling? I’ve always just stuck with the default that f360 throws at me, but it occurs to me aluminum might need a different touch.
Climb for sure. Lionkev recommends it in the aluminum cutting guide. I did try conventional a couple times. For removing material, the chips looked thinner and…mangled? More twisted? I also tried on a finish pass and it looked awful.
Awesome, thanks. I see Ryan asked the same question 3 years ago.
I cant seem to figure out how to do those clean sweeping passes, they mention “trochodial” milling and that fusion 360 doesn’t have it. But I cant seem to find what program they are using.
Fusion calls it Adaptive clearing
I swear I checked them, but I guess I didn’t post it, and we all can see how my brain is going so you KNOW I don’t remember. Fortunately, I haven’t made any trips to the recycler since, well, a long time so those pieces are likely still in my scrap pile. I’ll see if I can dig them out and report back. I’m not expecting stellar results because the chatter tells me I was lacking rigidity, and see the exchange above.
Ok great, I didn’t see there were 2D and 3D adaptive. I’m no F360 pro, so don’t over estimate my enthusiasm for knowledge
Well, i think I got to the bottom of that movement problem, but I still have one question.
I thought turning on arcs would help, but it did not. So I got to learn a little about g2 and g3. I sent some commands through repetier host (rh), and it made circles. Nice.
Run the program, garbage. I think I flashed the firmware at least 20 times with different settings. Read a ton of internet, learned a little about junction deviation and jerk (although it’s still largely over my head). Still nothing. Well, not true. I did manage to make it worse. I counted 24 segments as the tool made it through the second corner.
Made a bunch of different types of arcs, speed, diameter, direction, and ran the program through rh. Looks great. Program still sucks.
I figured it would be a good idea to run the code a few lines at a time through rh. I started with the arcs version, and i saw it. -g2, G1, g2, G1…
Opened the no arcs and started counting. Over FIFTY lines per corner. What the? Not 24? Ok. So about half of them are close enough in direction to not trigger acceleration? But what about the arcs… Why so many? Wait. SONOFABITCH. The profile was a fusion projection of an stl. Bunches of little lines, some of them approximated by arcs.
So, I’ve got a clean circle, a bunch of clean circles, a clean squircle with different radii on each corner, and a quick manual trace of the same plate that gave me problems, 4 lines, 4 arcs, bam bam bam. And now I’ve forgotten what my question was.
That is a lesson. Whenever you have an issue - try to reproduce it in simplest case made from scratch.
