Gentlemens, welcome back to the shop, today we have a threat especial: the chinesium 3040 milling machine!
[attachment file=38540]
[attachment file=38541]
[attachment file=38542]
[attachment file=38543]
[attachment file=38544]
[attachment file=38545]
[attachment file=38546]
This one is entirely made of aluminum, with linear ball bearings and ball guided screws. Seems pretty rigid, not entirely perfect since the Z axis has a tiny little amount of play if you apply fairly good pressure on it, but it is far less than what I have on the MPCNC.
As many people were wondering how the MPCNC actually competes with other CNC structures, I think it could be instructive to post my new build here, so I can try to make a somewhat objective comparison between both systems I own!
So far, I’ve put all my energy this weekend to make it work, but I haven’t got time to actually try cutting something yet.
I’ve only purchased the chassis. For the electronics, I’m using a similar setup as for the MPCNC: Arduino + ramps + MPCNC firmware. The difference is that I don’t use the tiny crappy drivers, I’m using some beefier TB6560 ones, capable of 3A per phase, in order to drive the bigger steppers. The only issue I see there is that those drivers are limited to 1/16 steps instead of 1/32. I’m wondering if this actually makes a visible difference in terms of cut quality. I hope not because 1/16 makes the machine pretty fast and torquey, it would likely be quite slow and weaker in 1/32. I’ll see if this proves to be a real issue, I always wondered about that. 640 steps per mm seems to be enough, at least in my noob opinion… Makes 0.0015 mm per step, I m’n not sure there should be any real difference going for 1/32 which would make 0.0007mm per step. In my opinion, backlash and other issues will happen far before we hit those numbers. But Maybe someone can correct me if my assumptions are moronic, I’m really no expert.
I reused some steppers I had for other projects, X and Y are pretty normal ones except for the fact that they are rated at 84V, and the Z stepper is some pretty big ass stepper, it was actually the biggest and the most powerful one I could find at that time. Not necessary at all, but I had to use whatever materials I had. right now I supply them with 12V and it works fine, but I’ll try to find a 24-or 48V psu in a near future.
I spent quite a bit of time doing the wiring, and I added limit switches for all axis in order to do homing. I’ll add a probe system later.
It’s ready to work now, I’ve checked and adjusted the spindle squareness, set the proper step/mm values, jerk values, max speed and so on, and it seems to chooches fine.
I’ll probably make the first milling tests this week, as usual I’ll post pictures. I’ll also try to make comparative cuts between both machines, to see which machines performs best at doing what.
Of course, don’t take those as scientific experiences, and keep in myind that my MPCNC is probably a bit different than yours, for instance it is likely of different dimensions, different table structure, even different bearing systems. But anyway, it might be fun and interesting to see.
Cheers!
