MPR&P trial
Smart move. Securing the split housing directly to the upper core keeps bearing tension adjustable without throwing off endstop trigger points.
I have also seen that you can “iron” the support top layer for a better finish,
I wouldn’t try that with a support layer.
Why? Just a chance to fail
I haven’t tried it myself yet but here´s the video I watched.
I printed one of the z lifts and than fitted to core
, than realised id stuffed up as to how high the router will sit
now my heads spinning out of control , im now second guessing myself on sso much of it
I need your input please, have I got this right
hope this makes sense
so what ive done is lengthened the bottom of the lift so its 25mm lower.
now bottom of x core will be 30mm off table at lowest point , and collet will be about the same.
at highest point collet will be approx. 167mm above table as per image
say slab is 70mm thick , a long 75mm ball nose, stick out about 45 =115 that gives me 50mm free play
i want try keeps pipes only as high as z lift which gives me 83 mm of travel from Z limit sswitch
to bottom
its main use, will be v carves , and 3drelife carves. max dimensions 600w x 800L height generally 50-70mm slabs or 18mm sheets
If i needed to do thicker slab my plan was print extenders to go under end supports ,
undo 8 bolts put in blocks, re screw to table
Although, if you can swing it, doing the full support in the incompatible material makes for some smoooooooooth top supports.
Pretty sure I used more PLA than the PCTG the parts are made of. :rofl:
Those are some great looking parts.
Looks really good. Did you design the support as a second part or was that automatically generated?
Those parts look like you are getting prepped for injection molding…you about to mass produce something fun Barry?
i actually tried the ironing on my last couple of prints ,
prints pla, main support, pla , 3 layers of pteg at top of support branches , with zero gap to part , it sticks real well , it dosent just fall off at end of print , you have to physically peel off the pteg
Did you design that yourself? That is nicely done!
Interesting never thought of ironing supports!
slowing getting everything printed, hopefully will have it all printed by the time my stepper motors turn up
