MPCNC PRIMO F-25mm NEMA23 CLOSED LOOP steppers
Thanks for the input Jeff… The holes on the Burly mounts seemed quite off when I measured the existing STL’s that I could find on Thingieverse… But I will probably design a mount specifically for this and try it out and let you guys know how it went…
As for the spindle, I did want to get something smaller, but unfortunately my choices are quite limited here if I want to source it locally… I could either get a small Dremel or this… Here you cannot get the DW660, and I did not want to go through ordering it from abroad, since the air traffic is super slow here because of the virus + the customs procedures, etc etc… So I risked a bit with this beefy spindle but we will see… My construction is made out of very tough stainless steel tubes (3mm thick walls) and they are super sturdy, I am just worried about the printed parts… I also have a beefier stepper for Z, if this one cant keep up with this spindle.
