I’ve imported all Ryan’s beautiful Primo parts into Rhino. While those are printing I’ve played around with size and layout before cutting wood and tubing or screwing down the feet. It helps to avoid mistakes or even worse, changing my mind. For example, I had the Y axis centered on the 2x4 MDF shelving. When I moved the core with router center to maximums I found the workspace was at the edge of the MDF. I moved the feet in the +Y direction to center the workspace. Better now than in real life.
