Here’s an STL of the lower mount with with fittings for the air jet.
660_Low_Mount_Air_V3.stl_.zip (3.08 MB)
Where is the bottom mount link for the dw660? I can only find the spindle one.
I hope this isn’t a silly question but I’ve been wondering, I’m waiting on a 3D printer and have never handled anything printed with a flexible filament material but is the material flexible and light enough to print a strip with ‘bristles’ or maybe separate segments ~1-2 mm wide that could be wrapped around the bottom of the shoe rather than trying to source a strip of brush somewhere?
@catogagen has done exactly that. There are a couple of examples in the forum history. My search-and-quote fu isn’t up to scratch or I’d provide more links. Try searching “flexible” and “brush”
Thanks! I guess I need a little work on searching.
The best Idea I saw was that rubber type of construction paper from a hobby store. Just hot glue it to the outside of the DC to make a skirt.
Boy, have I been out of touch. I had no idea such a thing even existed but it sounds like it may very possibly be a plan.
I don’t know how to describe the stuff. It comes in colors, it is made out of some kind of rubber or plastic. It comes in letter sized sheets. People use it to cut out stencils, or like high quality construction paper. It isn’t as “fabric-y” as felt, and it is thicker than construction paper.
What Jeff mentioned is EVA foam and it sounds like a great idea. The brush bristles are stiff and can cause issues with Z height once they start touching your material. EVA foam is very pliable.
Yes, thank you:
https://www.amazon.com/dp/B07TBRX97Z
(these are very cheap at a local store, and you don’t need 80 sheets).
Thanks all! Sounds like something to put in my planning, I’m pretty much a believer in KISS engineering whenever possible.
I’ve used eva foam for dust ruffles but it’s a little soft and quickly gets sucked into the orifice and plugs up. I tried leather, same thing. I did two layers of polyester felt cut in strips and that was ok, but still not stiff enough. I need bristles.
I don’t use a 660 anymore, I’m using a 611 on a Shapeoko now. (mpcnc is now a lowrider) I reworked an existing vac adapter for the 611 to include a brush - the same brush I used with my 660 mount. The brush was rigidly attached to the vac adapter and the vac adapter was rigidly mounted to the 611. I had to make it to where the brush could float up and down and rotate a bit because whenever the machine made a 180° move on the xy plane, the brush bristles would actually lift the entire z axis! I never encountered this with the 660, but it may happen to some degree and flexible brush material might be worth a try.
This is most likely a totally dumb question, does this work on the Primo? Or has it been adapted to fit the mount? Thanks in advance.
–BA
