So I caved in and put it on thingiverse. Seems like the best way to manage it.
Great job Tom! I like it. Looks well designed and thought out. No doubt you will make it better with a little more testing.
I gotta say I love this setup. I installed it immediately when I got my MPCNC setup and the difference it makes it huge. Granted the only way I can tell is by turning the vacuum on and off and the air pump on and off butboth make a big difference. I purchased a small airbrush compressor from harbor freight and it works great with this setup. Just wanted to say thank you for sharing it with the community! I am hoping to mimic the bottom mount and have a little larger hole for my vacuum so it doesn’t put as much stress on it but other than that I love it. If you happen to be willing to share the cad files please let me know. I will immediately send back any modifications I make so you can add them to your thingiverse listing.
I’m glad it is serving you well. These are links to my Fusion360 files. If you do make changes, please put them on thingiverse as a remix of the original. I am a self-trained designer, so I apologize if my drawings are ratty. I’m certain there are a million “best practices” that I trample.
https://a360.co/2KtHOvk Dust Shoe
http://a360.co/2mDsm44 Air Jet mount
https://a360.co/2JIbQtL Cap for bottom of DW660 if you remove the built-in “wrench”
https://a360.co/2HHCmqI Top outside part of mount
The inside part of the top mount is a direct rip of Ryan’s original 660 mount
**Edited: Found what I was after.
Grave digging this thread a bit… After gumming up a few aluminum cuts I’m working on something similar using the burly mount as the base.
The location of the 90* fitting avoids making contact with the bottom of the middle assembly.
That is a nice idea for all materials.
Ryan, you don’t release the drawings for your parts (specifically tool mounts), do you? Working off of STLs has been doable but not the most pleasant experience. And while recreating models of the mounts has been a fun exercise in learning CAD, it’s certainly not quickest way to go about modifying parts.
Edit: Link to part mentioned by Ryan below: https://www.thingiverse.com/thing:805803
I have a blank mount with a solid file to work with on thingiverse.
I have literally tried for many hours to “beef up” Toms dust shoe design. Ive found (for me anyway) the vertical wall is too thin at only 1.x mm and for whatever reason my McMaster Carr brush is WAY too tight and breaks my walls there too. I use designspark mechanical (and love it) but editing the STL is not an option here. Ive tried to edit the original files Tom provided but my lack of 360 knowledge has only gave me a sore back sitting here at the computer.
Sooo, If anyone could makes Toms design a little beefer in those ares I’d GREATLY appreciate it. As is, I have a dust shoe that wont do me much good. Thanks
I’ll release mine when it’s wrapped up. Waiting on the brush material in the mail now.
Ryan, any issues people releasing “reverse engineered” drawings? Don’t want to step on any toes here.
What dims are missing from my blank part drawings and solid file, on thingiverse?
For getting something to mate to the tool mounting plate itself, none. For the lazy, like myself, not having to recreate the wheel and model the other half that mounts to the tool is nice as well.
That is what I mean isn’t my blank part the dewalt lower mount?
Sorry for the confusion, I’ll clarify. I meant models for something along the lines of the burly mount itself. Such that I don’t need to re-model the part that clamps the neck of the DW660. Unless I’m missing something (and I’m new so I very well may be) I don’t think models for the burly mounts themselves are made public.
When I look at https://www.thingiverse.com/thing:805803 I see a models for this:
[attachment file=84282]
I was originally asking if you released models for the burly mount itself. I was left to recreate things like this for the mount with the air jet added:
[attachment file=84279]
Just added it for you.
I’m still hacking away at this. I think I’ve got the lower mount pretty well sorted. Ended up making ports on both sides of the mount such that the elbow and air line can be placed on either side. I’ve sealed the unused side with a printed plug. I’m still working out the design of the shoe - I’d like to make the shoe removable without the need to remove the lower lock piece.
Likely an over optimization but It’d also be pretty slick if brush height was adjustable. Either by printing different brush mounts and making them easy to swap or making the brush mount itself have different mounting locations.
[attachment file=84933]
Had time to finish up enough of the burly vacjet to make some 1.5" square test cuts in 1/2 inch ply. Inital cuts looked good. Even with the far from optimal ziptied hose management the sizing of the parts looked just about spot on. Still a few kinks to work out though:
Length of skirt relative to depth of cuts
Angle / placement of the air jet
Skirt material that everyone is using in this thread is really rigid stuff. So rigid that I think it may be worth thinning out to reduce the force needed for it to flex and give during cuts.
I’m going to go through a few more iterations over the coming days/weeks and publish the drawings / STLs thereafter. So far the design hasn’t required the use of any supports while printing. Hoping to keep it that way.
[attachment file=“85241”]
[attachment file=“85242”]
[attachment file=85265]
[attachment file=85266]
This worthy of it’s own thread or shall I continue hijack this one?
The shoe still needs a bit of tuning but I’m very happy with the progress thus far. Made several aluminum cuts today with no gumming up of the bit. I do need to run another circuit in the garage, however. Managed to start popping breakers with the compressor, vac, and router all running simultaneously.
Short clip of the air jet doing its thing in some 1/8" aluminum: https://imgur.com/T29XnOb
