MP3DP "Repeat" serial number log
Claim your Build’s serial number here!
Instructions at the end of this post.
This printer first printed 2021-08-27 -
This is the V1 Engineering MP3DP "Repeat"
Serial - 000001
Took it’s “finished” form on 2021-09-18
Instructions for Serial numbers.
This is the V1 Engineering “Repeat” Serial - 000001 (the placeholders are extremely wishful thinking).
When you think your build is done enough to print. Take a picture, add it here (preferably with a little info), claim your number and display it. If you are unsure what your number is, it should be one higher than the post above yours, it will also be show when you click on the time stamp on the upper right of your post.
You can post and claim as many numbers as you have builds.
No purchase necessary
No other posts in this thread.
MP3DP “Repeat” serial number 000002
310mmx310mmx275mm build volume, 1/2" plywood frame with MDF marquee. Shown here before final cosmetic completion. Still needs the bottom endstop wires extended and tucked away, LED lighting completed.
First print 10/16/2021
2 posts were split to a new topic: New Printer?
MP3DP “Repeat” Serial Number 000003
300x310x330 build volume, Vulcano Hotend, 1/2" Plywood construction.
Build start - November 01
First Print - November 16
Build finished - December 7.
Building Thread
Looks Like I forgot to post this one so,
MP3DP “Repeat” Serial Number 000004
11/20/21
MP3DP “Repeat” Serial Number 000005
Uploading: PXL_20220225_003841891.jpg…
First print 2/25/22
Is that bamboo?
No, vaneered ply. Some of the leftovers from the first LR2 build.
I guess this idea petered out? Or serial number 000006. :joy:
