Mozaik setup
I’m trying out mozaik cabinet software. Has anyone used it before and got their Cnc connected and working properly? I’m looking for guidance on how to get mozaik working perfectly with lowrider v4 and fluid nc.
thanks
It seems really expensive, I don’t think any of us have ever used it. If it can export gcide, you can use it to generate the code. Looking at the price tag, it should be able to.
I know it can, just looking at settings wise if anyone has dealt with it. I’m just using the trial to see if it’s worth the price.
Oh, good… for a second, I read it as “Muzak setup”, and was concerned about the potential aging of our user base…
Since none of us have used it the easiest way I can think of would be to export the full sheet dxf (or other vector drawing). Then we can help you with the cut paths in regular CAM. Once you get the hang of that you should be able to translate over what you learned pretty easily.
