I was calibrating my LR3 and I wanted to speed it up a little. I changed something in Marlin settings so now if I need to move X axis to the side of the table it only takes 610mm to get there, before it was 1220mm. Did I adjusted something and now for each 1mm that I want to move motors move by 2mm? I tried to look for solution but I can’t find anything. Is there a cheat sheet with default settings? Thanks for any help
If you didn’t save the changes, you can reset it by powering down and back up. M500 saves rhe settings. M502 resets everything to the firnware defaults (you still need M500 to save them). M503 prints most settings to the console.
