Lowrider 2 - Z axis losing steps
Good morning,
Finishing an LR2 build that I’ve had around for ages (lack of time). Build is complete, but I’m encountering an issue
If I drill one area without raising the toolhead, all is fine. But on the second area where the tool head need to be raised to reach it, it actually drags on wood, and the resulting cut is deeper. It seems it’s losing steps when raising.
We confirmed this by removing the spindle, and simply adding a little bit of pressure on the stepper motor, we could hear the stepper motor losing steps.
Reading through some material on this forum, I’ve found to leads to investigate:
1/ Check VREF level
2/ check Z connector for second stepper motor and ensure it’s using a dedicated mosfet
the control board is a mini Rambo, and there start my problems…
On 1/, I could not find material on the Internet that would allow me to adjust Vref. Looks like mini Rambo control the stepper motor current using a PWM, and it’s defined by SW when compiling Marlin. Not exactly practical for trial and error, unless I missed something ?
On 2/ Indeed, I’m using both Z connector. The connector next to it is free (E0), but I’m unsure if the default firmware will use it to control the second stepper motor. I’m using V1 engineering mini Rambo firmware, no change
I tried to look in the firmware source code, but i’m not too familiar with Marlin config option, and could not find where dual stepper motor driver could be defined
To note:
  • we use Fusion360 with the post processor, and don’t touch the G-Code
  • We checked the coupling, tightened the coupler screws, and added grease to the leadscrew
  • When drilling the first pocket, depth is constant, it’s when raising that it fails to raise all the way
See picture of three consequent areas drilled during the same phase, first area is fine, second area is deeper than what it should be, third area is even deeper (from bottom to top)
Any advice would be appreciated
Regards
Using the 2 Z connections the way you are is splitting the current between the 2 motors, resulting in much less available torque. You’ll need to reduce the Z max velocity and acceleration or move the second Z motor to the E0 connection. I don’t run a Rambo (or mini Rambo) myself, but I think if you’re using the Dual Endstop version of the firmware it should be set to use the other stepper driver for the second Z motor by default.
I’m not exactly sure how you have this board wired up. There are two stepper motors on the Y and the Z axes, and I don’t believe E0 is set up for the second Y stepper motor. The Mini Rambo board only has 4 drivers, so Ryan spec’ed the wiring to be serial/series for the X and the Z stepper motors. You will find the wiring diagram for serial/series wiring under the “Archive” link at the bottom of this page.
Ryan no longer sells the Mini Rambo nor the series/serial cable. If you purchased your system from Ryan, you should have received the serial/series wiring harness for the Z motors. I had an idea based on a post on the forum. If I was going to make a series/serial wiring harness, I would start by purchasing a set of these. I would then cut the traces on this board and wire jumpers to make this a serial/series connection. This keeps the wiring clean, plus it makes it simple to upgrade the system to a five-driver control board in the future.
As for adjusting the current, you will need to recompile the firmware. For Windows, PlatformIO is the recommended software for recompiling and flashing the firmware for the Mini Rambo board. You will find the source for the firmware on this page, and you want the V1CNC_MiniRambo version. The current is set in this line in configuration_adv.h:
#define PWM_MOTOR_CURRENT { 850, 850, 850 } // { 1300, 1300, 1250 }          // Values in milliamps
The Mini Rambo uses A4982 stepper drivers with a max current of 2A. What I don’t know is whether the current settings in PWM_MOTOR_CURRENT are Max or RMS. Regardless, I would increase the current with caution, and pay attention to the temperature of the stepper motors. Given the PLA used for the brackets, it is possible to run the steppers hot enough to melt the PLA. Note that you should not need to adjust the current if you use serial/series wiring.
If you are using serial/series wiring, there is some benefit to running your control board at 24V, though there are many builds that just used 12V.
Thanks for this information
I stand corrected, I checked the wiring, and they are indeed in series.
The mini Rambo is powered through a 12V power supply. I’ll try a 24V power supply.
I’ll also try increasing PWM_MOTOR_CURRENT values (I assume I only need to change the Z axis).
Increasing to 24V will only help with rapid movements. It will have no impact on normal (cutting) movements. Series wiring reduces the torque for rapid movements, and going to 24V can help if that is where you are losing steps.
There are a lot of successful LR2 builds at 12V and default current settings. I suggest you check for some sort of mechanical issue…lead screw bent or misaligned, screws need to be lubed, grub screws on the connector loose, etc.
Well, we checked everything, and it’s clearly mechanical
It seems the Y-plate (built using 12mm MDF) is flexing during movement, causing a lead screw alignement. Not sure if it’s the quality of the MDF material used, or something else.
We’ll continue to look at mechanics while getting Y-plate in an alternate material
It’s a pretty common recommendation to allow a little wiggle in the mounting of the lead screw nuts to the structure. You don’t want up-and-down slop, but if the nuts can self-align when the leadscrew itself is moving a bit due to flex elsewhere in the machine, that might help alleviate the symptoms you’re seeing.
