Is there a code to get the reading of T0? It seems like this new mega is not reading the resistor. I checked the resistor with my meter and it is fine.
Going to run a M119 tonight to see if the end stops are reporting properly. Even though it still does not move with the end stops unplugged.
It would be my luck though if this Mega board was defective upon delivery, and of course the guy is not responding on ebay. Claim time I guess.
Woot! Got my new new Mega 2560 and now all is function as expected… Do I understand correct that I need to use dxf2gcode to vector engraving with my laser? and img2gcode for raster engraving?
I’d only use dxf to gcode for vector files that are just plain line drawings. I use it exclusively for PC board work.The only advantage being that dxf2gcode will do a line drawing much faster by following the path of the actual line instead of raster over the entire image, pixel by pixel, line by line, the way image2gcode will. Anything that has fills in it or a photograph will be slower, but much better, with image2gcode.
