Thank you so much! I will put the modified file on Thingiverse when I finish it.
Hi Kees,
you have already helped me a lot, but I still have a problem that maybe you could help me with.
Could you please suggest me a link to download the printer firmware for the SKR-pro v 1.2 and for TFT35 E3 V3.0 Display? (I think they are the cards you used for your MP3DP)
Many thanks
Best regards
Paolo
I use the SKR 1.4 Turbo and not the 1.2 Pro. As for the screen, I just use the standard firmware from the Bigtree Github page…
Thanks Kees, this is a good starting point for me.
BR
Paolo
It looks like you printer is underextruding a bit or your Z is a smidge to high…
Succes! You can take this firmware as a reference / start to build you SKR 1.2 Pro - firmware. And ofcource, when you succeed, publish it somewhere over here
It always looks like that under a raft…forgot to uncheck that box. If I don’t print a raft it seems to look much better. The rest of the printing looks good to me. Is that normal under a raft?
Ah, that’s why I never do use a raft
Rest of the print looks ok! How did the bridges turn out? I was realy suprised how much better the MP3DP is with bridges compared to my (trusty old) Delta.
The bridges look good to me… a little stringy at first but I’m using an ancient Makerbot that probably should have been retired long ago…I am looking forward to building the MP3DP and tinkering with something new. My daughter is drawing designs to carve in her flat stock now…we will have a fleet of 3D printers soon if all goes right!
Very nice
Can’t wait to see your first print from it, and see the build for your daughters.
Both printers are fully functioning. My daughters’ build is the video some post above
