I installed the cp210x driver and made sure I had the right usb cable. I followed the steps that this site has used but nothing seems to work. I even tried a different computer. same results. I bought the jackpot3 from V1. I’m using on a lowrider 2 . Using windows 10.
In what way is it not working? As in how do you know it is not recognized?
Windows 10 has been deprecated for a while, it could be due to that but it definitely used to work.
In device manager it unknown usb device
I upgraded to win 11 still doesn’t work
By far the most common issue is a power only usb cable, please double check this one. Unplug the power cable and use the USB only.
Does the jackpot power on and show you the webui?
yes it does
This cable is the same one I use to transfer data with my phone and I tried other cables I have. When I jog the x and y axis 100mm, x goes 100mm y goes 20 mm. They are both set at 50 mm per step.
You can do all config changes in the webui. Use the save config macro.
Solving computer connection issues is very difficult. If you want to use a computer the easiest thing to do is try another computer, something seems off with the usb on the one you have?
Make sure $ss in the terminal shows no errors.
My gut says it is not a config issue.
I tried another computer same problem. I didn’t want make any changes in config file until was sure I knew what I was doing. I was wanting get the usb fitted so I can tranfer files
I’m not sure what to check next in terms of USB.
So lets look at the CNC itself.
Where did the jp3 come from?
Where did the steppers, and wires, come from?
Have you always have this issue?
Are you sure the pulleys for X and Y are the same tooth count?
Do both Y steppers move the exact same distance everytime or vary?
What if you move 1000mm?
jp3 use bought from v1 this month. the lowrider is about 5 years old. The old controller was damaged so I upgrade to the jp3. the steppers move the same every time. I think bought the stepper and wire and the old controller from v1
Okay, so that means I flashed it using USB before it left so that is tested good, unless something happened between here and there.
Okay the only thing that would make sense is if you have the Y axis plugged into the Z axis ports. On the lowriders the X and y axis have the same steps…the Z axis is different.
Or somehow you have differnt pulley sizes on your Y axis.
When the yaxis is jogged 100 mm it travels about 245 mm’ There is no slippage. Same motors and same pulleys. The y axis plugged in y port. Thy motors are connected together the same as when I was using the Rambo controller.
I am confused.
What lowrider are you using a LR1? 4 wheels on each side?
lr2 2 wheels on each side
Okay, so what happens when you move the Y axis 100mm, it moves 50mm or 254mm?
I am assuming you are homing all axes first. Then using the jog panel to move one click, 100mm?
It should have said 1000 mm went 250 mm
So somehow you are moving 1/4th the desired.
Maybe you need to upload a clean config file, maybe the microsteps got changed. The microsteps should be 8, did you change them to 32?
