Ok so I am trying to get some things ready while my parts print, and I’m sure this has been covered but i can’t find it. The jackpot 3 board comes from the V1 shop with the config file for the lowrider, if I intend to use it for a primo, do I need to change this and if so how do I go about it.
Files for Jackpot 3 for Primo can be found here
You can upload the config.yaml through the web interface, or through the File Manager at http://installer.fluidnc.com with the board connected to your computer
Ok do I delete the other first so only 1 config file shows up or can the file names be modified to tell a difference?
Yup just upload the one yaml file and reboot
Uploading will overwrite
ok this all worked out fine, my only question left here is : when i open the yaml file in a text editor it says Lowrider. That is the file directly downloaded from github under jp3 MPCNC. Just made me question if I’m doing somthing dumb or not.
Yup I need to change the text, the config is right though
Awesome Thanks for all you do.
