Jackpot 3 - no response from Y MAX endstop
Had a breaker trip while cutting, after resetting and attempting to home, the Y MAX endstop was not being recognized, I switched the Z and Y on the Jackpot to see if the endstop or it’s wire were the problem, it worked fine, it seems to be the the PIN 35 position is no longer working. I pulled the board to see if I had melted anything - nothing visible, looks like new. I’m not sure where to go from here, everything else works normally, just the YMAX board connection is failing. Any advice would be appreciated, thanks.
You can change the config.yaml file to move the switch to the spare pin. Open it with notepad and change pin 35 to 39, be careful not to add any extra spaces.
Super odd that the pin would die. I have no idea how that could even happen.
Thanks Ryan I’ll give that a go.
The move to pin 39, worked perfectly, the config change was easier than I was expecting. Thanks again.
