Issue with Relay for Spindle Control - Mini-Rambo
I’m trying to incorporate a relay into my MPCNC to turn the spindle on and off. I’ve successfully wired the relay into FAN 1 of my mini-Rambo board and am using M106/M107 commands to turn it on and off. Trouble is, as soon as the M106 command hits - the the router turns on, briefly, and then the mini-Rambo resets itself.
Any help as to why this is happening would be much appreciated. Pic below of my relay:
UPDATE: I switched the mini-Rambo power supply from the NORMALLY ON to the ALWAYS ON outlet…and it worked perfectly.
[attachment file=79800]
Thanks in advance!!
The first possible cause that comes to mind is the initial power draw of the router starting up is causing a brief brown out to your main board’s power supply. Kind of like when you turn on a vacumm cleaner or something and you see the lights in the room dimm briefly. What do you have the Main power supply and your Relay plugged into? Directly to a wall plug or some sort of battery backup? Try to separate the two and see if it happens again.
I have my main board power supply plugged into a battery backup to prevent these kinds of minor brown outs from resetting the brains. But I quickly learned I couldn’t use the router on the same battery backup. My relay is now plugged directly into the wall.
The normally on side flips off when the normally off ports flip on.
Thanks fellas, appreciate the responses. Barry hit it on the head, the NORMALLY ON shuts off when the relay is activated which is what I had the board plugged into. I didn’t see that anywhere on the box or online instructions…live and learn!
Thanks!
