Just make sure you have your alignment right.
Does anyone using the lowrider 2 without endstops have any tips on how to easily / quickly square the material to the machine?
I cut this piece out and as you can see it was a little off square.
I cut two grooves at 90 degrees into the table about 10mm deep at my origin point and then inserted a strip of MDF that was 20mm wide which gave me a removable right angle fence that I used to align my parts with.
You could also cut some holes for dowels and use the dowels to align the work.
Thanks, do you have any examples in photos?
