Importance of Table Flatness/Levelness
There’s a section on it in the docs:
"Your table needs only be as fancy as a sheet of wood on a relatively flat, smooth surface. A CNC can self correct many of its own imperfections if needed. "
There was also bit of discussion on tables recently here:
This was addressed too, but I can’t find it. Just relatively flat is fine.
If you are doing sheet goods and through-cuts, 100% not a problem.
If you are doing fancy carves in thick material, you are likely to need to surface the material before cutting anyway, and you shouldn’t have a problem.
“Relatively flat” and “smooth” are the only thing you absolutely need to shoot for.
Don’t stress over it.
If you want a quick sanity check, you can get a 6’ level or long straight edge and lay it across and shim the MDF from underneath.
I did this for under my rollers, but 1mm is not a big deal.
