Help with Firmware Skr 1.2 tft35 v3
Hi everyone, I’m very new to this. I have my kit for my lowrider2 a year ago but due to health problems I had not been able to do anything. I wanted to know could you help me with the firmware for Skr 1.2 tft35 v3. I don’t know if there will be a place to find the files as if there is also a video or guide to know how to update the firmware. I hope you can help me thank you very much.
This website has extensive knowledge all at our finger tips.
https://docs.v1engineering.com/software/#firmware
That will guide you here for Downloads.
https://docs.v1engineering.com/electronics/marlin-firmware/
I put the firmware for TFT like instruction but now the screen is like this. Some idea why is this?. Sorry for my English.
According to the above, that means the skr cannot talk to the Drivers.
Do you have the drivers installed, and jumpers correct??
This information gives me from Repetier-Host. I really don’t understand much, I’m more than a novice at this.
18:31:33.853 : FIRMWARE_NAME:Marlin 513DL 2.0.9.2 (Oct 24 2021 13:38:26) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 513DL EXTRUDER_COUNT:0 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
18:31:33.853 : N9 M220 S100104
18:31:33.853 : N10 M221 S100
81
18:31:33.853 : Cap:SERIAL_XON_XOFF:0
18:31:33.853 : Cap:BINARY_FILE_TRANSFER:0
18:31:33.854 : Cap:EEPROM:1
18:31:33.854 : Cap:VOLUMETRIC:0
18:31:33.854 : Cap:AUTOREPORT_POS:0
18:31:33.854 : Cap:AUTOREPORT_TEMP:0
18:31:33.854 : Cap:PROGRESS:0
18:31:33.854 : Cap:PRINT_JOB:1
18:31:33.854 : Cap:AUTOLEVEL:0
18:31:33.854 : Cap:RUNOUT:0
18:31:33.854 : Cap:Z_PROBE:1
18:31:33.854 : Cap:LEVELING_DATA:0
18:31:33.854 : Cap:BUILD_PERCENT:0
18:31:33.854 : Cap:SOFTWARE_POWER:0
18:31:33.855 : Cap:TOGGLE_LIGHTS:0
18:31:33.855 : Cap:CASE_LIGHT_BRIGHTNESS:0
18:31:33.855 : Cap:EMERGENCY_PARSER:0
18:31:33.855 : Cap:HOST_ACTION_COMMANDS:0
18:31:33.855 : Cap:PROMPT_SUPPORT:0
18:31:33.855 : Cap:SDCARD:1
18:31:33.855 : Cap:REPEAT:0
18:31:33.855 : Cap:SD_WRITE:1
18:31:33.855 : Cap:AUTOREPORT_SD_STATUS:0
18:31:33.855 : Cap:LONG_FILENAME:0
18:31:33.855 : Cap:THERMAL_PROTECTION:1
18:31:33.855 : Cap:MOTION_MODES:1
18:31:33.856 : Cap:ARCS:1
18:31:33.856 : Cap:BABYSTEPPING:0
18:31:33.856 : Cap:CHAMBER_TEMPERATURE:0
18:31:33.856 : Cap:COOLER_TEMPERATURE:0
18:31:33.856 : Cap:MEATPACK:0
18:31:33.856 : N11 M111 S6*87
18:31:33.964 : X:0.00 Y:0.00 Z:200.00 Count X:0 Y:0 Z:80000
18:31:33.964 : echo:DEBUG:INFO,ERRORS
18:31:33.964 : echo:No media
18:31:33.964 : echo:Unknown command: “M80”
18:31:33.965 : echo:Unknown command: “M221 S100”
18:31:33.965 : echo:DEBUG:INFO,ERRORS
18:37:54.715 : N161 M12236
18:37:54.719 : X Y Y2 Z Z2
18:37:54.719 : Address 0 0 0 0 0
18:37:54.797 : Enabled true true true true true
18:37:54.798 : Set current 900 900 900 900 900
18:37:54.837 : RMS current 887 887 887 887 887
18:37:54.877 : MAX current 1251 1251 1251 1251 1251
18:37:54.878 : Run current 28/31 28/31 28/31 28/31 28/31
18:37:54.878 : Hold current 22/31 22/31 22/31 22/31 22/31
18:37:54.918 : CS actual 22/31 22/31 22/31 22/31 22/31
18:37:54.919 : PWM scale
18:37:54.959 : vsense 1=.18 1=.18 1=.18 1=.18 1=.18
18:37:54.999 : stealthChop false false false false false
18:37:55.038 : msteps 16 16 16 16 16
18:37:55.079 : interp true true true true true
18:37:55.119 : tstep max max max max max
18:37:55.119 : PWM thresh.
18:37:55.119 : [mm/s]
18:37:55.158 : OT prewarn false false false false false
18:37:55.159 : triggered
18:37:55.159 : OTP false false false false false
18:37:55.198 : pwm scale sum 25 25 25 25 25
18:37:55.238 : pwm scale auto 0 0 0 0 0
18:37:55.278 : pwm offset auto 36 36 36 36 36
18:37:55.318 : pwm grad auto 14 14 14 14 14
18:37:55.358 : off time 3 3 3 3 3
18:37:55.399 : blank time 24 24 24 24 24
18:37:55.399 : hysteresis
18:37:55.439 : -end -1 -1 -1 -1 -1
18:37:55.478 : -start 1 1 1 1 1
18:37:55.479 : Stallguard thrs 0 0 0 0 0
18:37:55.518 : uStep count 632 888 232 56 88
18:37:55.519 : DRVSTATUS X Y Y2 Z Z2
18:37:55.558 : sg_result 0 2 2 2 2
18:37:55.597 : stst
18:37:55.639 : olb * *
18:37:55.678 : ola * *
18:37:55.717 : s2gb
18:37:55.757 : s2ga
18:37:55.797 : otpw
18:37:55.837 : ot
18:37:55.877 : 157C
18:37:55.917 : 150C
18:37:55.957 : 143C
18:37:55.997 : 120C
18:37:56.037 : s2vsa
18:37:56.077 : s2vsb
18:37:56.079 : Driver registers:
18:37:56.087 : X 0x80:16:00:00
18:37:56.095 : Y 0x80:16:00:00
18:37:56.103 : Y2 0x80:16:00:C0
18:37:56.111 : Z 0x80:16:00:00
18:37:56.119 : Z2 0x80:16:00:C0
18:37:56.127 : Testing X connection… OK
18:37:56.135 : Testing Y connection… OK
18:37:56.142 : Testing Y2 connection… OK
18:37:56.150 : Testing Z connection… OK
18:37:56.158 : Testing Z2 connection… OK
18:37:57.051 : N162 M105
34
So the info looks good. Do you have 2 pair of power connections??
Yes, the power to the board and from there a bridge to power the motors. The motors are handled by Repetier, but if I want to move them from the touch screen, the message “printed not attached” appears and the motors are not moved. That’s normal?. Because my idea is to drive the lowrider2 directly without a pc, can this possible?
In the screenshot, the screen is in marlin mode. But it shows the tmc connection error.
In the response from repetier host, the tmc error has gone away.
In tft mode, you’re getting no printer attached, which is most likely that the baud rate in the screen needs to be set to 250k.
But, I would advise you to go back to marlin mode for now. The tft mode isn’t as reliable as marlin mode. I think the tmc error will go away. I’m not sure what caused it, but the repetier host printout shows they are fine. In marlin mode, you can click the wheel to get to the menu.
Thanks jeffe. I wasnt able to help anymore. I was just searching tmc errror
It is correct in Marlin mode it is working fine I can move the motors. Thank you very much. I have the table ready, I just need to buy the steel tube and start to assemble lowrider2. Once I have assembled if any doubt arises again, I will bother them again. Thank you very much.
Fix “no printer attached” message issue with TFT display. In the video I show how I did it, looking in the menu I found what you told me about the baud rate. Maybe it can help someone else who has the same problem.
